FP Red+Cobb Pro-Tune= Booya
Old Jan 24, 2013 | 08:46 PM
genelee112601's Avatar
Great Number!!
Question where did u get the 93 Octane @ Cali ?
Old Jan 25, 2013 | 07:18 PM
clichere1's Avatar
Originally Posted by utggevox
Wow very nice numbers and spool for pump especially for Cali 91 pisstane! Just curious is your red JB or BB?
I'm not sure ... it's 2 years old FP Red. I bought it because it was in great condition.
Old Jan 25, 2013 | 07:22 PM
clichere1's Avatar
Originally Posted by genelee112601
Great Number!!
will , I took 10 gallons of 100oc with me, and Cobb mix it with 91oc to get something near to 93oc.
in Qatar we have 93 (97 RON) at the pump, $1.09 a gallon. SWEEET
Old Feb 1, 2013 | 02:58 AM
Gyroscope's Avatar
how do you spool it so fast? fastest red spool ive seen and with stock displacement???
Old Feb 6, 2013 | 01:30 PM
papatel's Avatar
Wow, this is exactly the setup I want. Op, do you mind providing a complete list of mods for everyone?
I'm about to build my 2010 Ralliart and with your permission, I'd like to copy you
Old Feb 6, 2013 | 08:47 PM
acidtonic's Avatar
Nice setup!
Old Feb 6, 2013 | 10:39 PM
clichere1's Avatar
Well I'm not absolutely sure, but i think because of these three mods :
afe dry intake stage 2 + cobb full piping kit + MAP tublar manifold
wild guess btw
Old Feb 6, 2013 | 10:40 PM
clichere1's Avatar
Originally Posted by acidtonic
nice setup!
thanx
Old Feb 6, 2013 | 10:44 PM
clichere1's Avatar
yap , no worries , glad to help everyone
ha ha ha , no need to take permission pal
FP Red
ETS 18"x12"x4" FMIC
ETS Test Pipe
Cobb UICP/LICP Hard pipe kit - grey
Cobb Turbo Inlet
Cobb XLE BPV - might go for Synapse BOV for louder blow
aFe ProDry Intake - stage 2
MAP coated DP
MAP short runner manifold
Grimmspeed EBC
Eibach Pro-kit springs
Walbro 255 FP - BLAQOPS FP install kit
ID injectors 1000cc
CNT RS Catback
Works SS
Kracka bushing kit - from MAP
& Cobb Pro Tune for 91oc and 93oc
Old Feb 7, 2013 | 03:46 PM
papatel's Avatar
Thanks! I'm emailing cobb socal now and telling them you sent me
One quick question: if the power you currently have is the cap of what I want, are there any of your mods that are not necessary? More specifically, I've been told many different things about whether or not I need to upgrade my manifold. Do you recommend I do it?
I've also been warned my car will output less because of the SST so I cannot hope for exactly the same results, but hopefully close
Old Feb 7, 2013 | 04:57 PM
utggevox's Avatar
A tubular manifold will give you more flow=more top end which=later spool so if you want spool over top end keep stock cams and just port/polish the stock manifold.
Old Feb 19, 2013 | 10:05 PM
novaspyder87's Avatar
im sure at 99.9% that the reason for its fast spool is his upgraded wastegate actuator!!!.....he didnt wrote it because some WGA looks like stock but have a 25psi spring.......so instead of opening the gate at 13psi(stock WGA 13psi spring)....well it just goes super fast to build boost since the gate is close makes sense no???
yessss even a short runner manifold will make it spool slower than stock...BUT the short runner make you loose something like 150rpm...compare to 500rpm for a full tubular manifold...and will give you some AWESOME power all over the powerband compare to stock!!!! even stock ported is NO match for a short runner.....refering to MAP testing their manifolds ......had cams like cosworth mx1 to keep the fast spooling and that car would be all over the place and a low low low 11sec car...if its not high tens !!!! gl BUDDY!!!! great setup :-p .......ps: i have the same or almost just different brands
Old Feb 24, 2013 | 12:42 PM
tgr24's Avatar
wow booyah indeed
Old Feb 27, 2013 | 07:57 AM
srt4killer's Avatar
nice
Old Mar 7, 2013 | 03:17 AM
clichere1's Avatar
Thank you all for your comments.
