Highest whp on stock turbo Evo X!!!
We did a little over 400 on 93 octane: https://www.evolutionm.net/forums/ev...402-399-a.html
It can be done.
~Chris@MooreAutomotive
Tuner/Master Technician
It can be done.
The only legitimate high hp stock turbo car I have seen was on a normal dynojet running 31psi with e85 and made like 410whp, no matter what you will not get much more than that on a stock turbo.
Higher compression motors are the only way to make that go further.
The thing that is silly about this, is that there are X's making 700+whp. Having a 411whp x isn't going to prove anything. Not only that, but numbers are retarded. Go for the fastest 1/4 mile or trap speed for a stock turbo X.
So, what's a "normal dynojet"? I think we would see more high(er) power stock turbo X's if people did cams on them like the 8 and 9 guys. I just don't understand why the X community seems to be against bigger cams on stock turbo. The stock cams are small and there's power to be had by going bigger.
I was on load boost then, so was only at like 27/28 psi but I would've been around 410whp I think.
Cams or no cams, 400whp on stock turbo doesn't happen without retarded timing.
I was running 24/25 degrees on this.
That power band looks like so much fun!!
Your idea is so good to break the record and build a best model. I think adding more power is one of the better way to make a good one so you can don this.Wait for your announcement of this new one.
