2013 gsr 325/292
Old Jun 11, 2013 | 07:44 PM
awdxftw's Avatar
Veteran: Army
2013 gsr 325/292
Tuned at Slowmotion Motorsports in Ohio open sourced. Now that i'm looking at the numbers on the dyno it says flywheel hp???? Also at WOT i'm at 10.0 afr. Seems too low right????
325 hp 292 tq on 91 octane 20psi
MODS:
AMS UICP
AMS TBE
ETS INTAKE
TURBOSMART BOV
ID 1000CC INJ
DW65C FP
grimspeed ebc
Old Jun 13, 2013 | 09:10 PM
btownsoccer22's Avatar
You shouldn't need injectors and a fuel pump with those mods. When you mean turbo back exhaust do you mean the AMS down pipe also? If so 325hp/292tq is low.
Old Jun 13, 2013 | 09:16 PM
bphx123's Avatar
why are u running fuel pump and injectors? and no graph from afr ?
Old Jun 13, 2013 | 09:39 PM
StormTroperX's Avatar
why only 20 psi?
Old Jun 14, 2013 | 03:57 AM
awdxftw's Avatar
Veteran: Army
yes ams downpipe, test pipe, single exit muffler.. Thats what I thought man, but it literally took him 6 1/2 hours to tune my car so I was like eff it!
I planned on dual map and doing e85. They talked me out of it until I got e85 compatible fuel lines in the fuel pump carraige and there is a submerged line in the fuel tank that needs replaced too. I'm buying a kit from balqops, and tuning for e85. I'll have them send me the other charts, this is all I got from them -_______-
Originally Posted by StormTroperX
why only 20 psi?
No clue man, he was scared pretty much...
Another **** thing was he said "I have an evo x, you have a little more mods than I do i'll be sad if yours makes more power than me" I was like oh yea lol smfh
Old Jun 14, 2013 | 03:02 PM
Who's your tuner?
Old Jun 15, 2013 | 08:47 AM
awdxftw's Avatar
Veteran: Army
I dont remember, maybe his name was adam? Either way in his defense he's conservative. I didnt know what psi people were running neither. So when I get my blaqops kit and I tune for e85 I'll def be going 27+
Old Jun 15, 2013 | 09:01 AM
bphx123's Avatar
take your car to someone else and get it retuned. If you have no one else closer to you look into etune.
Old Jun 15, 2013 | 09:09 AM
Wicked_White10's Avatar
You went to the wrong people man. You don't need fp and injectors for the mods you have like others said unless you are going to go e85. You should be seeing higher numbers also. Good luck, hope you find somewhere else to go.
Old Jun 15, 2013 | 09:59 AM
awdxftw's Avatar
Veteran: Army
Originally Posted by wicked_white10
you went to the wrong people man. You don't need fp and injectors for the mods you have like others said unless you are going to go e85. You should be seeing higher numbers also. Good luck, hope you find somewhere else to go.
eeeeeeeee-888888888855555555555555
Old Jun 15, 2013 | 10:33 AM
btack's Avatar
I'd be scared to get my car tuned at a place called "Slowmotion"
Fastmotion maybe
Old Jun 15, 2013 | 10:50 AM
awdxftw's Avatar
Veteran: Army
^ lol ironic name for a speed shop I know. They have a couple 8 second shop cars and their one of Ohio's premier speed shops. Just dont know what happend here.
Old Jun 15, 2013 | 10:54 AM
Showbizz41's Avatar
Do they tune/build a lot of X's??
Old Jun 15, 2013 | 10:58 AM
awdxftw's Avatar
Veteran: Army
no, thats another thing they have a 8 sec Viii they've tuned maybe a handful of x's. The guy who tuned mine has a X his is also conservatively tuned. He didnt want to overdo it you know. I was just seeing if my numbers were low. After the overwhelmingly negative responses i'll take that as a yes lol.
Old Jun 15, 2013 | 11:01 AM
Showbizz41's Avatar
Low yes. If you're happy with it, don't listen to what other people have to say! But, knowing you can get more, take that into consideration. We weren't there for the conversations you had with him to know both sides. In many cases you'll just get a handful of people that will sling a bunch of **** because they dont see numbers they would expect
