Boostin Performance- 2013 stock turbo GSR
Old Dec 23, 2013 | 06:37 PM
Prosdoc's Avatar
Wow! What a difference from the stock tune. The car has come alive As usual, excellent customer service from Devin and Kristin at Boostin. Everything went smoothly and all questions were answered. I would recommend them without hesitation.
Mods:
-ETS single tip CB and HFC test pipe
-ETS UICP
-ETS intake
-Grimmspeed 3 port
Also had Devin hook up the AEM Boost/AFR Failsafe gauge and program it for safety to cut boost if it exceeds a preset limit.
Mustang Dyno,
93 octane
-Pre-install (stock tune and no power mods): 236whp/244wtrq
-Post-install and tune: 304whp/312wtrq
Take a look at the dyno sheet overlay with pre and post #'s. Area under the curve has increased dramatically. Car feels very solid!
3rd gear pull:
2-3-4-5 gear pulls
Old Dec 23, 2013 | 10:53 PM
dab262's Avatar
Nice numbers. Just get rid of that HFC and you'll be on your way! Boostin FTW!
Old Dec 24, 2013 | 07:18 AM
Prosdoc's Avatar
Thanks. I stuck with the HFC for emissions, smell, and I didn;t want to increase drone. Surprisingly, the HFC actually enhances the growl and minimized any drone I had from the single tip CB
Old Dec 24, 2013 | 03:58 PM
GodRealm06's Avatar
Nice!
Old Dec 25, 2013 | 11:21 AM
Dahmer's Avatar
Serious gains
Old Jan 1, 2014 | 09:27 AM
Boostin Perform's Avatar
Thanks for posting your experience Glad you're enjoying your new found power
Old Jan 4, 2014 | 04:31 PM
Prosdoc's Avatar
No prob. Really loving the new power and drivability. I actually don't think I've ever been to a tuning shop that is as clean, as meticulous, and as courteous as Boostin. Keep it up
Old Jan 5, 2014 | 04:53 AM
GottaZtt's Avatar
boost change from stock?
Old Jan 5, 2014 | 09:14 AM
Bhsj13's Avatar
Very nice, enjoy your new founds power!
Old Jan 5, 2014 | 08:24 PM
Prosdoc's Avatar
Peak boost is now 26 psi
Old Jan 7, 2014 | 07:00 AM
Thank you for the kind words
The later model Evo X's (2013-2014) see around 22 psi for peak boost. So 4 PSI over the stock tune, but the boost curve is much smoother then stock, and doesn't drop off nearly as much.
Old Jan 13, 2014 | 07:37 AM
evojay85's Avatar
Great Numbers. Assuming stock clutch still?
As long as you don't launch it or drive heavy, what kind've mileage will you see out of the stock clutch with basic bolt ons and tune? That's the only thing holding me back from tuning the car.
Old Jan 14, 2014 | 05:23 AM
Prosdoc's Avatar
Yes, still on the stock clutch. From what I've read, it seems like "400wtrq" is the limit for the stock clutch (but of course that also depends on which dyno you're talking about). Maybe Boostin will chime in and add some info....
Old Jan 22, 2014 | 10:33 AM
Getting a tune on a stockish Evo X will not shorten the life of your clutch. Its more about how you drive the car. A clutch only wears when it is being shifted / slipped. A good safe limit is 400 WTQ on a Dynojet and 360 WTQ on a Mustang Dyno.
We have tuned numerous Evo X's making 350+ on our Mustang Dyno and they are still on there stock clutches today.
Old Jan 27, 2014 | 11:00 PM
kaquino's Avatar
Awesome numbers for those mods
