-   Evo X Dyno Results (https://www.evolutionm.net/forums/evo-x-dyno-results-298/)
-   -   MAP's Evo X Exhaust Manifold Testing / Dyno Results (https://www.evolutionm.net/forums/evo-x-dyno-results/546971-maps-evo-x-exhaust-manifold-testing-dyno-results.html)
ChrisCarey Mar 25, 2011 02:02 PM
http://www.maperformance.com/img/forums/evom-header.jpg
http://www.maperformance.com/img/forums/tb-maprace.pnghttp://www.maperformance.com/img/forums/tb-whymap.pnghttp://www.maperformance.com/img/forums/tb-services.pnghttp://www.maperformance.com/img/for...-clearance.pnghttp://www.maperformance.com/img/for...-customers.png
http://www.maperformance.com/img/forums/sep.png
Test Overview
As a follow up to our recent Evo 8 & 9 testing we decided to bring in another car and test a few exhaust manifold upgrades that we offer for the Evo X platform :) I do not know the ins and outs of this car (perhaps Dave can chime in) but I do know that its on E85 and sports an FP Black with supporting mods. We used Dave's more conservative street tune for the testing, keep in mind that no changes to the tune / boost level / etc. were made during this testing so those numbers do fluctuate a little bit. It's also important to note that the baseline here is an MAP ported stock manifold, enjoy!
http://www.maperformance.com/img/forums/sep3.png
MAP Ported Exhaust Manifold vs. MAP "Short Runner" Exhaust Manifold
Boost was a touch higher between 4500-5500, but there were substantial gains throughout the power band! As you can see it spools a little slower but power output is very similar during spool up. +26whp & +13ft/lbs over our ported stock manifold for just $569.99 shipped? I think we had better place another stocking order!
http://www.maperformance.com/img/Por...SMAPShort2.jpg
MAP Ported Exhaust Manifold vs. MAP Tubular Exhaust Manifold for Evo X
Our in-house fabricated tubular manifold performed admirably with peak gains of 24whp & 18ft/lbs over the ported stock manifold, but we were surprised to say the least that it came in 10whp less peak than the short runner above (although the short runner appears to have been at a higher boost level when it achieved peak whp). We decided to make a revision to the routing of one of the runners and were pleasantly surprised by the results as gains up to +33whp & +26ft/lbs were realized :) Needless to say this revision will now be permanent.
http://www.maperformance.com/img/Por...APTubular2.jpg
http://www.maperformance.com/img/Por...edTubular2.jpg
Conclusions
The results from the short runner were surprising to say the least. Ultimately I think our revised long runner will yield the biggest top end gains and its built like a brick, but its hard to overlook the value in that short runner! Also, we did a little more testing in response to a recent competitor's post that isn't included in this thread for political reasons, the only comment I will make regarding that is that I am confident our tubular manifold is the absolute best performing unit on the market :)
http://www.maperformance.com/img/forums/sep2.png
kelvar13 Mar 25, 2011 02:05 PM
wow great results! another set of quality products from you guys. Kudos!
murlo26 Mar 25, 2011 02:23 PM
Mods:
Buschur Bullet Exhaust
UR Testpipe
AMS Downpipe
AMS IC
AMS UICP/LICP
Primo 3.5" intake
FP black - ported heat coated
Blouch 21psi WGA
Built Motor - AMS Spec JE pistons, Manley TT rods, Cosworth bearings, stock sleeves stock crank
Built head - Ported/polished, +1mm valves (supertech) w/supertech springs
GSC S2 cams
Baseline w/ported n Coated stock mani - obviously changed manifolds
DW 1400cc Injectors
MAP AFPR kit
BlaqOps Progressive boost double pumper
E70 fuel
ACT 6 puck w/ ACT streetlite flywheel
Magnus CMC
That's all I can think of for now, probably missing something but this is the bulk of it!
I sat in the passenger seat while Jordan drove for all the testing and have logs for everything if anyone has doubts. Thanks MAP for the opportunity, it was fun!
smoothevo Mar 25, 2011 04:12 PM
Have anything comparing the stock manifold to the short runner? I'm assuming the short runner vs. tubular would be for someone looking for quicker spool, like me?
jwwu Mar 25, 2011 06:30 PM
1. Are there any dyno results for stock OEM exhaust manifold vs. posted OEM? I think that would be of interest to loads of folks here. Preferably with a less "built" car on pump gas, pls.
2. Who makes the short runner for MAP? The layout looks similar to the Tomioka that you also sell and to a number of designs for sale on ebay
Great testing results! To be frank, it looks like the short runner at high RPMs is showing stronger gains than the full length manifold?
Thanks for sharing.
jOnLiMiTeD Mar 25, 2011 08:48 PM
Wow, great numbers.
murlo26 Mar 25, 2011 10:40 PM
Thanks for sharing.
It's also running more boost if you look at it. It's a very very strong mani, but the longer runnered mani's will show better topend when fully tuned I think.
Wht9er Mar 26, 2011 04:22 AM
what boost controller are you using?
armysoldier1073 Mar 26, 2011 04:48 AM
CAn you use a tubi Manila for a stock turbo and get good results?
jwwu Mar 26, 2011 05:28 AM
Yup... the one thing that's missing - and hard to account for in these comparison - is the ideal tune for each manifold.
Kudos to MAP for these comparisons.
murlo26 Mar 26, 2011 10:01 AM
Perrin 3 port
smoothevo Mar 26, 2011 10:12 AM
Don't forget about me... is the short runner more for quicker spool vs. the longer tubular?
whitecomet Mar 26, 2011 10:29 AM
nice to see the effort to improve your product.
ChrisCarey Mar 28, 2011 08:59 AM
Exactly, however the Evo X version seems to hang pretty well on the top end as well which differs from our Evo 8 & 9 testing.
Slow98teg Mar 28, 2011 07:23 PM
Nice results. Def going on the future parts list lol
