will blue tooth be available for the GSR X
Old Feb 11, 2008 | 07:10 AM
  #31
RKT SHP's Avatar
and what is this "steering wheel audio control" is that a part that comes on the lancer
Old Feb 11, 2008 | 09:06 AM
  #32
PDXEvo's Avatar
This is great news man. Where did you get the steering wheel switch?
Old Feb 11, 2008 | 11:03 AM
  #33
R0ME0's Avatar
Lookin good antics! You have pics of the conrol switch mounted? I hope this will work with no NAV. thats what i'm hoping for anyway. Where does the mic mount?
Old Feb 11, 2008 | 11:51 AM
  #34
antics22's Avatar
Yes, i took pics but i have to get them off the camera tonight when i get home.... It SHOULD work without nav, but I have yet to test since i need to plan a trip to the dealer so they can activate the feature....
Old Feb 11, 2008 | 11:52 AM
  #35
antics22's Avatar
Got it through the dealer... I have the part number at home. Ill update you and through a how-to when/if i can get everything to work.
Old Feb 11, 2008 | 02:53 PM
  #36
antics22's Avatar
Heres a pic. I took it just now with my co-workers camera.
Old Feb 11, 2008 | 02:57 PM
  #37
antics22's Avatar
Originally Posted by RKT SHP
tell us more about this reverse camera that you speak of.......and is this using the stock nav deck
stock nav deck. Camera is an universal Pioneer unit.
Old Feb 11, 2008 | 04:30 PM
  #38
RKT SHP's Avatar
Dude you got to post up how you did the rear camera
Old Feb 11, 2008 | 05:07 PM
  #39
mksevo's Avatar
hey, , where is the yellow video RCA hook up. and can you give us a cost yet .
thanks
Old Feb 12, 2008 | 01:32 PM
  #40
R0ME0's Avatar
Do you have pics of where the mic mounts?
Old Feb 12, 2008 | 03:27 PM
  #41
mrdecibel's Avatar
If I was a betting man I would think the mic is in the map light cluster. There is a perforated section in between both lights. Most OEMs place the mic there.
Old Feb 12, 2008 | 04:07 PM
  #42
tb_evo's Avatar
I know for the lancer they can buy the blue tooth as an accesory and have it put on there lancer. Does anyone know when the MR comes out(as it has blue tooth) will we be able to get the blue tooth for the GSR also.
Thanks for bringing that up coz I also want to know if it was available for the GSR. My brother-in-law just bought a lancer GTS. His car came with the Nav and bluetooth.
I know the bluetooth is standard for the EVO X MR, but I don't think it would be available for the GSR. The Nav option is only available for the GSR, but with no bluetooth.
Old Feb 12, 2008 | 05:20 PM
  #43
PDXEvo's Avatar
You can buy the bluetooth kit thats used on the outlander and the base lancer. You can then install this kit into your GSR without any issues. Then you will need your dealer to use their MUT-III programmer to enable the feature on your car. Once thats done, you will need to get the hands free steering wheel mount. Without it, you cant synch your phone, or anything like that. Once you have that, you are done, because I havent figured out how to enable the thing yet.
Though the wiring harnesses exist, the current issue, from my schematics tracing, is the soft switch in the S-AWC ECU is currently set to run the S-AWC selector switch from the steering wheel. This needs to be changed to radio/hfk setting somehow.
Old Feb 12, 2008 | 06:35 PM
  #44
EmanantEvo's Avatar
That would be a winning bet. That is where it is in the GTS.
Old Feb 12, 2008 | 06:51 PM
  #45
EmanantEvo's Avatar
You can read up on a camera install on a 08 Lancer here. It should be fairly close if not the same as an install on a X.
https://www.evolutionm.net/forums/sh...d.php?t=311198
