Tips for eliminating rattles in rear
Old May 4, 2008 | 12:18 PM
mrdecibel's Avatar
Remove heat shield above muffler.
The heat shield is held in by (4) 10mm nuts. Remove those and slide heat shield out.
Add padding to rear deck cover
Remove rear deck cover by pulling rear pillar covers out. The pillar is held in by a single panel connector in the middle and a strap on the top. Just pull out enough to lift off rear cover. The rear cover is held in by (5) white panel pins underneath and (2) black ones on outside. Once removed, place more foam or padding to cover all plastic areas. Problem area in my car was at very back of panel near window. Below are pictures of pillar detached and rear panel with no modification.
Old May 5, 2008 | 08:45 PM
boostedawd's Avatar
very nice...except my rattles are coming from the front.
Old May 5, 2008 | 11:48 PM
evox_'s Avatar
same here... center dash.
I was looking at the hood this weekend, and the air-guide for the air scope on the hood looks like it's kinda flimsy .I haven't done any investigation with that though
Old May 6, 2008 | 08:25 AM
tsitalon1's Avatar
Is this for the rattle you get when you close the trunk...like a tink, tink sound?
Old May 6, 2008 | 01:21 PM
mrdecibel's Avatar
Not sure if I ever observed that sound.
Rexpeed
Evo 'For Sale' Exterior Styling
100
Aug 7, 2011 08:26 AM
talentsearch301
19
Jun 27, 2009 05:40 PM
Evo8
Apr 29, 2009 02:28 PM
mrdecibel
May 29, 2008 08:17 AM
Celica2EVO
Jan 30, 2008 12:46 PM
