anyone else with an MR have this problem?
Old Jul 16, 2009 | 01:11 PM
industry's Avatar
occasionally when i start my car, the nav boots up and does its normal thing. then when i try to use the audio controls on the steering wheel, the buttons are all mixed up. i always hoped that if my car were possessed, it would like go out and run over my foes... this is just annoying.
volume up: BT voice command
volume down: track up
track up: volume up
track down: volume up
mode: volume down
the BT and cruise control buttons work normally though.
is there a reboot/reset button somewhere that i don't know about?
Old Jul 16, 2009 | 04:58 PM
Jimyumi's Avatar
Never happen to mine, everything works perfectly! What about have your dealer check it out?
Old Jul 16, 2009 | 06:11 PM
contagius's Avatar
nope.
Old Jul 16, 2009 | 06:42 PM
industry's Avatar
glad to hear you're not having problems.
i am going to take it in, but wanted to possibly see if anyone else had this issue. living in northern california, i've found it difficult to find a dealership with a reputable history in servicing evos. taking it down scm would be what i want to do, but still a month away since i don't go down as often. that is why this thread was started.
Old Jul 16, 2009 | 07:14 PM
salukidude's Avatar
I think those controls connect to a harness under the cup holder. I wonder if the harness is backwards or if the wires aren't connected to the right pins. It doesn't make any sense how that could happen, though. I think there is a thread in the audio section where a guy installed the bluetooth himself. He detailed those connections under the cup holder. Check that out or just ride it out until you can get to SCM.
Edit: Actually, that post is on another evox_forum. I can't give you the link cause they'll censor it, but the post is called
HOW TO: Installing factory Bluetooth into Evo X GSR
Old Jul 16, 2009 | 07:42 PM
atombomb33's Avatar
EvoM Community Team
Weird that it happens intermittently. Sounds like a faulty connection at one of the wiring harnesses (probably the one inside the steering wheel). See what the dealer can figure out. Good luck.
Old Jul 16, 2009 | 10:11 PM
industry's Avatar
thanks.
that is the thing that gets me too. i start the car, system boots up, winds up not working properly. wait a few minutes while i'm driving and try it again... it works! weird, but it seems to happen more often when the weather is warmer. also, the reason why i ask if anyone knows of a reset/reboot button/method for the mmcs.
cheers.
Old Jul 16, 2009 | 10:50 PM
salukidude's Avatar
Oh, I missed your 'occasionally'. I swapped out the MMCS long ago and don't know how to reset, or if there is one. Maybe try disconnecting the battery for 10 seconds.
