OEM AMP location for non-fosgate Evo X
Old Aug 7, 2009 | 12:34 PM
devinclfalcons's Avatar
Where is my oem amp located? I do not have the optional fosgate package.
Old Aug 7, 2009 | 12:58 PM
klaysta's Avatar
There is no external OEM amp. The amp is built into the head unit.
Old Aug 7, 2009 | 01:01 PM
evolutionXmute's Avatar
it is under the drivers seat.
Old Aug 7, 2009 | 01:40 PM
klaysta's Avatar
That is if he has the Rockford Fosgate system.
Old Aug 8, 2009 | 08:35 AM
Wink
I have the p400-4 Rockford amplifier I purchased. What are the dimensions of the own Fosgate amp? Will mine fit under the driver seat?
Old Aug 8, 2009 | 11:25 AM
c_reber's Avatar
That should fit just fine. Unless they have something else under there. Mine had the factory RF system, and it had a ton of room after I removed my factory amp. But as klaysta said, NON-RF system has no external amp.
Old May 20, 2010 | 01:38 PM
08Lancer89's Avatar
will the factory RF amp plug into a non RF lancer? is it pre wired???
Old Oct 10, 2012 | 05:59 PM
USMARINE4LIFE86's Avatar
It may be pre-wired. I see a hook up harnest in the trunk of my car where the RF sub goes, and I do not have the RF system in my car. You would need the RF sub for your exact year and model if the wires are there. I reccomend aftermarket for sure. I have a 400 watt Kicker amp as my multi-channel. If you do use the oem RF amp, I would change your 61/2 door speakers all around. There is a good chance the added power will blow them.
Old Oct 31, 2012 | 09:54 AM
M1ster_jayjay's Avatar
The Non RF systems do not have the wiring from the radio to the amp location under the seat. You will need to run your own wires.
ALT3REVO
Apr 25, 2017 04:01 PM
domyz
Aug 16, 2016 06:01 PM
gptoyz
10
Oct 21, 2015 02:19 PM
dhe_answer
Sep 22, 2015 05:15 AM
eyelobes
49
Apr 22, 2011 12:51 PM
