Rear seat shelf rattle from subwoofer
Old Dec 7, 2009 | 10:24 AM
Webman's Avatar
Originally Posted by AD_LIB
I have this too, it got much worse when i added a 12" sub and 400 watts ...I had my installer add some dynamat but it didnt fix it seems like the deck is rattling against the rear window at certain frequencies.
So it's actually rattling against the rear window, and not against what's underneath it? Interesting.... That would mean that putting foam under it wouldn't make any difference.
Old Dec 7, 2009 | 03:38 PM
JMotz's Avatar
I'm not sure if this helps, but I thought my rear deck was rattling. Tried stuffing all kinds of stuff up through the trunk. Put felt along the back edge. I think I finally found the problem, it was in the passenger side C pillar. When I pulled off the cover, there is a round metal clip about half way up I believe around the air bag, It was rattling against the frame. I bent this a bit away from the metal frame and no more rattle. Might be something different than your rattle, but it sounded like the rear deck but was actually behind the C pillar. If it comes back I'm planning on putting a little felt behind it.
Jon
Old Dec 8, 2009 | 01:52 PM
total0wnage's Avatar
i went to the dealership today about this and a recall i had, he said he put some stuff under my rear shelf to stop the sound and that didnt solve the problem so i left because i didnt have much time but im going to investigate this more today and try to figure out the exact location, im gonna check the spots u guys suggested
Old Dec 16, 2009 | 02:11 PM
saytheb's Avatar
Off topic but good, I'm glad you are fighting with them. I walked away from them when I was looking at buying my X.. everything there gives off a slime vibe to me. Maybe others had better experiences. Let me know if they fix this for you..
Old Dec 23, 2009 | 10:26 AM
Webman's Avatar
Dealer is having some stereo shop do some work to the car today to fix the rattle. We'll see how it works out...
Old Jan 16, 2010 | 04:30 PM
flyboytb's Avatar
when I had my x I had the same problem with the rear shelf rattling between the glass and whatever is underneath. I used some weatherstripping from home depot that is for sliding glass doors. its about 1/4 inch thick. I sandwiched this between the glass and the shelf and it really helped a lot. I spend a whole weekend hunting rattles lol.
Old Jan 16, 2010 | 05:28 PM
Optiblue's Avatar
I diagnosed mine to the sub enclosure rattling... something inside is loose
Old Mar 15, 2010 | 08:30 AM
Webman's Avatar
Well, the dealership hired some dude and paid him $50 to come in and stuff a couple pieces of foam between the plastic and the window. What's funny about this is that I specifically told the dealer that the plastic was NOT hitting the window, and that the sound was coming from underneath. Well, it didn't fix the issue, obviously.
So, last night I pulled out the rear seat and popped up the rear shelf. I stuffed a couple of rags in specific areas, and now the rattle is gone. about 45 minutes of my time and it's fixed.
Proof that if you want something done right, you do it your fu*king self.
Old Mar 20, 2010 | 04:29 AM
DarwinX's Avatar
That and dealership monkeys that work in the shop are retarded.
Old Mar 30, 2010 | 12:32 PM
emxracer's Avatar
This car loves to rattle
Old Mar 31, 2010 | 08:41 AM
Spy007's Avatar
Mine rattles too... ill work on fixing mine eventually lol
Old Apr 1, 2010 | 08:09 AM
Webman's Avatar
Mine doesn't rattle anymore. I put some sound damping material up there, and added a bit of other filler, and it it silent, even with my new sub.
Old Apr 1, 2010 | 09:33 PM
MitsuLancer00's Avatar
My 09 ES with the Rocksord Fosgate also rattles and it is the real deck.. i'm going to try your guys suggestions to get it fixed. my 2010 didnt have this problem at all i could turn up the bass passed 3 and it would be fine.
Old Apr 2, 2010 | 08:24 AM
Webman's Avatar
See, that's what I'm sayin. Very inconsistent. Some cars do, some don't.
Old Aug 30, 2012 | 07:22 PM
Bitner16's Avatar
I also ended up having to fix a few rattling issues but I think I have a rattle still in that same place. It sounds like there is something loose in the sub enclosure.
Have you fixed your issue? If so, PLEASE tell me how you did it!
