iphone plug into AUX , noise in the back .
Old Feb 4, 2012 | 11:34 PM
xXEVOloverXx's Avatar
hi guys, i bought a AUX cable ,plug my iphone4 into AUX port ,the sound quality is not good plus there is noise in the back, anyone know how to fix this ,maybe i got the ****ty cable .
Old Feb 4, 2012 | 11:56 PM
importunerdj's Avatar
yeah when i had my 2010 i had a $1 cable from the dollar store plugged it in with my iphone. It was definitely clear, try with another rca
Old Feb 5, 2012 | 03:27 PM
JRally's Avatar
I have a cable from Radio Shack and it's pretty noisy too, picks up a pretty bad ground loop whine.
Get the shortest cable you can, like 3' or less.
Old Feb 6, 2012 | 07:09 AM
CaptainAsia's Avatar
Dont charge your phone at the same time...
Old Feb 6, 2012 | 07:17 AM
Get Rad's Avatar
I notice the same thing when I am charging my phone.
Old Feb 6, 2012 | 07:28 AM
ugakirk's Avatar
+2 Don't charge anything at the same time. I heard it was because something is grounded properly.. I don't really remember and I'm not very "electrically gifted". I think all the X's do this. Mine is really bad when I don't have anything plugged in and set the radio to AUX.
Old Feb 6, 2012 | 08:12 AM
ProjectGSX's Avatar
This.
You get feedback through the AUX port if you are also charging the phone.
Old Feb 6, 2012 | 08:16 AM
mshilto89's Avatar
Same as everybody else said, don't charge anything while you have it plugged into the AUX. It will cause interference to come throught the speakers. Actually if you pay attention you can hear the noise increase the higher your RPM's are at. It's because the higher your RPM the more electrical energy your alternator is putting out which in turn causes the interference with the charger/AUX/Radio
Old Feb 6, 2012 | 09:11 AM
i never charge my phone in my car, but one thing that i can lower the noise in the back is turn the volume all the way up from the phone and turn the volume lower from my car ,it will be better, but i think it shouldn't be like that .
Old Feb 6, 2012 | 09:54 AM
Wildcat Birdie's Avatar
with any of these aux jacks, the device plugged in should be at the highest volume, this helps cut down on "noise"
Old Feb 6, 2012 | 12:56 PM
Crester's Avatar
You should listen to AUX-IN with your device turned all the way up. Otherwise the car is going to have to work harder to amplify the incoming audio signal... and it will amplify everything... good and bad... hence you hearing background noise.
Old Feb 6, 2012 | 07:44 PM
AV6JT's Avatar
isnt there a conversion out there to install fuse in older model X's? wouldnt that be better than an AUX cable?
Old Feb 6, 2012 | 08:02 PM
ugakirk's Avatar
That would be cool. I've never heard of that before though.
Old Feb 7, 2012 | 02:57 PM
JRally's Avatar
Charge or not does not change results on mine. In using an Android. I get the noise in aux mode with nothing but the cable plugged in, but it is a 6ft cable.
Old Feb 7, 2012 | 06:02 PM
EvoXChii's Avatar
I'm having the same problem, I have a 3ft cable i bought from best buy for about $40.00 I heard if you buy a "Group Loop Isolator" it will fix the problem.
