Help with turning signals with vland headlights .
Old Sep 1, 2018 | 12:43 AM
Ewokplayer's Avatar
So I brought a pair of vland headlights and they did not come with instructions. I got them in and working however the turn signals are not working front or back. And also there is a wire that runs from each headlight to the fuse and I do not know with fuse socket to hook them up to. Please help
Old Oct 3, 2018 | 12:29 PM
Zero115's Avatar
I haven't finished wiring my headlights in yet, but I'll help you if I can. I have my tail lights in and working. What model Evo do you have? and do you have stock projectors? As far as the tail lights, I can say at the very least, double check the plugs, when I first plugged mine in my blinkers and brake lights etc worked, but none of my running lights worked, it turned out one of the metal contacts on the plug got bent and wasn't making contact properly.
Old Jun 3, 2019 | 09:48 AM
Roccy's Avatar
Figured out that the extra harness was only to make the drl’s running all the time which is what I don’t want
