Reverse/Back up Light
Old Jan 30, 2020 | 04:03 PM
BenMara's Avatar
5 Year Member
Is it common for the reverse/back up light to come ON for few seconds then go OFF? Just noticed this after changing them out for LEDs, will change them out for incandescent bulbs and give an update.....
I just thought it was really ODD...
Old Jan 31, 2020 | 12:47 PM
BenMara's Avatar
5 Year Member
Replaced LEDs with incandescent bulbs, reverse lights work as before... going a different route for reverse bulbs
This adaptor
Amazon Amazon
With these bulbs.
https://www.amazon.com/Sylvania-58896-35BT4Q-Single-Halogen/dp/B007X41XY8?ie=UTF8&qid=1510363962&sr=8-4&keywords=GY6.35+12V+ir&tag=amazonquery-20 https://www.amazon.com/Sylvania-58896-35BT4Q-Single-Halogen/dp/B007X41XY8?ie=UTF8&qid=1510363962&sr=8-4&keywords=GY6.35+12V+ir&tag=amazonquery-20
Old Jan 31, 2020 | 03:58 PM
splattj's Avatar
That's really common. If there's not enough load on the circuit, the reverse lights turn off after a couple seconds
Old Jan 31, 2020 | 05:05 PM
BenMara's Avatar
5 Year Member
some solutions were resistor pack. But my purpose was for more Lumens in reverse. Thats why im going with a GY6.35 bulb and a 168 to 7440 bulb adaptor.
More Lumens when its dark outside and tint is too dark
Old Jan 31, 2020 | 10:43 PM
Nicholas Landis's Avatar
Led
Anyone use the leds
Old Feb 1, 2020 | 07:24 AM
BenMara's Avatar
5 Year Member
i have LEDs from LASFIT in the rear except for Reverse
Old Mar 3, 2020 | 08:02 PM
BenMara's Avatar
5 Year Member
So the Gy6.35 HIR bulbs go out after 3 sec like the LEDs did.
LEDs not enough resistance
HIR too much resistance
Lower wattage HIR?
Old Mar 4, 2020 | 10:22 AM
splattj's Avatar
The OE bulb is somewhere between 10-20W so if you can find an LED that draws closer to that you should be ok. I had a 10W LED bulb in my Ralliart that worked fine but the first set I bought were 8W and would go out. Of course, those wattage figures were spec sheet, I never put a meter on to check the actual draw.
Old Mar 4, 2020 | 10:13 PM
BenMara's Avatar
5 Year Member
LEDs just dont put out enough light for me. thats reason i went with GY6.35 HIR bulbs
Old May 20, 2020 | 08:12 PM
BenMara's Avatar
5 Year Member
Doing a custom harness to fix this problem
Old May 22, 2020 | 09:00 AM
six40's Avatar
I have LED's in mine and they stay on for however long its needed. Not sure what brand as they came with the car when I bought it year ago.
I also have LED's in my Escape's reverse lights, those are Philips and no issues with that one either.They really help shine light down my long, narrow and dark driveway when I back up at night.
Old May 22, 2020 | 10:34 PM
BenMara's Avatar
5 Year Member
I need more lumens that any LED can put off cause of the Dark Tint and back roads i live on
Old May 23, 2020 | 05:11 AM
splattj's Avatar
Hopefully those halogens don't create enough heat to warp/melt the reverse light housing. I'm sure modern plastics are better but higher wattage/wrong tail light bulbs in the 80s and 90s led to some pretty melted reflectors. It's also likely that, being reverse bulbs, they won't be on long enough to cause problems.
If that doesn't work out for you, you could always relay up a super slim LED bar under the center of the bumper. You might even be able to french in a couple of the square flood lights on either side of the license plate. I'll admit, it's not as clean but better than scraping the whole side of your Evo along something backing up at night.
Old May 24, 2020 | 09:39 PM
BenMara's Avatar
5 Year Member
The idea came from reading this thread on a different forum im on
https://www.tacomaworld.com/threads/...r-leds.474996/
Ev0la
Nov 3, 2016 07:15 PM
cliffsevoviii
Mar 18, 2006 11:22 AM
hbmike
Mar 17, 2003 02:01 AM
