VLAND tail light problems
Old Aug 4, 2020 | 10:07 AM
ProjectGSX's Avatar
After installing the tail lights, I noticed that 1 out of every 10 times or so that the headlights are turned on, the Stop light / Parking lights would not function. I have never had any troubles with the turn signals or the reverse lights. This is just about the Stop/Parking lights. After some digging, I figured out that, when this failure state occurs, the Parking lights flash 3 times and then both the stop and parking lights stop working. Turning the lights off and on again fixes the failure state, but again it happens every 1 in 10 or so times the headlights are turned on. As far as I can tell, if they are working when they are turned on they continue to work until they are turned off.
My first thought was that the units were defective. I now have 3 sets of these tail lights. Two full sets in smoke and 1 full set in red. All three sets do the same thing. The stock lights work fine.
Any suggestions? The install seems super simple. Im not sure where I am going wrong.
Old Aug 6, 2020 | 05:46 PM
1012Xmr's Avatar
i just installed mine no issue with the taillights but they only been on for a week if anything comes up ill let you know
Old Sep 22, 2020 | 09:05 PM
Wilvert Serrano's Avatar
have you fixed your problem? Did you figure out what it was? I’m having the same problem, and can’t figure it out all the wiring is correct and checked all my fuses
Old Jan 24, 2021 | 09:33 AM
Samuel Cook's Avatar
Any new info on this? I’m having the same problem.
Old Aug 26, 2021 | 04:31 AM
Jimmywang950's Avatar
Any updates?..having the same issues with no solution..thank you
Old Nov 11, 2022 | 06:02 AM
eking11's Avatar
Any updates? I have the same issue
EvoJoeIX
Feb 15, 2011 05:21 PM
TBevonine
Nov 27, 2007 03:06 PM
TBevonine
Nov 17, 2007 04:18 PM
the scholar
Jul 4, 2007 10:03 AM
Mouse
Oct 25, 2004 01:03 PM
