2008 GSR Power Drain - Fuse #8
Old Nov 23, 2020 | 05:41 PM
gta__'s Avatar
I have a 2008 GSR that I’m getting a .5 power draw at the battery when I did a parasitic draw check. Found that fuse 8 is causing the draw which looks to have a control in like everything hahah. With that fuse out, I’m getting .04-.06
Any recommendations on things to try/check to see if this problem can be solved without a dealer visit? Anyone else had a similar issue? What was your cause?
thanks in advance for any advice!
Edit - Solved. Testing error. Once we did a few more draw tests, noticed the meter would read .5 at first, but then settle down to .06 to .10.
Last edited by gta__; Nov 29, 2020 at 07:21 PM. Reason: Somewhat solved. No need to bump post.
jpisha
Dec 2, 2016 09:14 AM
Evo1ved
Evo X Dyno Results
Aug 12, 2013 07:10 AM
Sharkbite2000
Oct 19, 2010 11:39 AM
David661
Oct 12, 2010 12:20 PM
panem
Aug 15, 2009 04:00 PM
