Evo X DRL Plastic Socket Burnt
Hey guys I just picked up 2011 WW Evo X a few weeks ago and when I got it, the passenger DRL was out. I bought a set of 1156 LEDs and swapped them, the bulb was all burnt and busted and even after put in LEDs the passenger side still didn't work.
I checked the socket and it was black and burnt. I am still under warranty but the car came with an intake and exhaust. Do you guys think Mitsu will replace that DRL socket? |
Anyone?
Intake and Exhaust has nothing to do with the electrical system; Only one way to find out and its to take it to them and see if they would warranty it.
Originally Posted by GinuwineEvo8
(Post 11252609)
most 1156 LED's don't work in Evos, try a regular bulb first
intake and exhaust will not void a harness warranty, but, try a regular 1156 first. I've had two sets of 1156 LED's that do not work in evo's. |
Originally Posted by ikt
(Post 11256493)
intake and exhaust will not void a harness warranty, but, try a regular 1156 first. I've had two sets of 1156 LED's that do not work in evo's. Apparently I need a whole new Pass Headlight to get the DRL working again....can't I just get a new DRL Harness? |
Originally Posted by Motordyne
(Post 11259015)
I swapped the LEDs from Driver to passenger and passenger still doesnt' light up, but driver still works. So it's not the LEDs. I took it to Mitsu yesterday and they said the socket is burnt and they need to send pictures to Mitsubishi.
Apparently I need a whole new Pass Headlight to get the DRL working again....can't I just get a new DRL Harness? but they'd rather bill Mitsubishi $2000 for a headlight ;) |
(Post 11259168)
of course you can
Ok so Mitsubishi probably isn't going to do anything, they keep telling me I have to wait. So I just bought another DRL Socket from someone parting out and spliced the old one.
This is the weird part, bulbs work fine on both sides now but the LEDs still only work on the driver side. Could it be because my bulbs are 12V? But then how do they only work on the driver side but not the passenger side? |
Flip the wires. LEDs only work with current flowing in one direction.
Most of the lighting system is connected to the CAN BUS system, you cannot just add an LED AFIK. You need to add a resistor in order to add an LED bulb to the system.
Originally Posted by wrx lol
(Post 11279336)
Originally Posted by deanob
(Post 11279597)
(Post 11280052)
wouldn't flipping the bulb do the same thing?
(Post 11280279)
Not for the 1156 socket. If you inspect the bulb, you'll notice the contact is on the bottom and all around the sides. Inserting the bulb into the socket and then twisting 180 degrees to reinsert would be the same thing. If you cut the wires to the socket and switch them then it would alternate the positive and negative current to that bulb.
