Evo X DRL Plastic Socket Burnt
Hey guys I just picked up 2011 WW Evo X a few weeks ago and when I got it, the passenger DRL was out. I bought a set of 1156 LEDs and swapped them, the bulb was all burnt and busted and even after put in LEDs the passenger side still didn't work.
I checked the socket and it was black and burnt. I am still under warranty but the car came with an intake and exhaust. Do you guys think Mitsu will replace that DRL socket?
most 1156 LED's don't work in Evos, try a regular bulb first
intake and exhaust will not void a harness warranty, but, try a regular 1156 first. I've had two sets of 1156 LED's that do not work in evo's.
Apparently I need a whole new Pass Headlight to get the DRL working again....can't I just get a new DRL Harness?
I swapped the LEDs from Driver to passenger and passenger still doesnt' light up, but driver still works. So it's not the LEDs. I took it to Mitsu yesterday and they said the socket is burnt and they need to send pictures to Mitsubishi.
but they'd rather bill Mitsubishi $2000 for a headlight
Ok so Mitsubishi probably isn't going to do anything, they keep telling me I have to wait. So I just bought another DRL Socket from someone parting out and spliced the old one.
This is the weird part, bulbs work fine on both sides now but the LEDs still only work on the driver side. Could it be because my bulbs are 12V? But then how do they only work on the driver side but not the passenger side?
Not for the 1156 socket. If you inspect the bulb, you'll notice the contact is on the bottom and all around the sides. Inserting the bulb into the socket and then twisting 180 degrees to reinsert would be the same thing. If you cut the wires to the socket and switch them then it would alternate the positive and negative current to that bulb.
