AMS Tuned
Remember this isn't an all out tune for power.. This is my daily driver with boost peaking at 24psi and the A/F at 11.4:1 under load. Spool up has been improved which directly enhances drivability.
As far as reliablity goes.. any modification you make to improve power could cause issues.. As far as I am concerned I think a nice safe tune is the best bang for the buck right now and will not be noticed unless the dealer starts digging into the ECU.
The car does have our Version 1 catback but the downpipe/test pipe is not ours (Unless it was a prototype from like 2003, but highly unlikely).Its all 3" mandrel bent and looks like it would perform as well as any other downpipe out there, so your still in good shape.
The car also have a K&N cone filter/adaptor, Autometer boost, a/f, oil press gauges, Hallman MBC (new style) which I set to 18-19 psi. I didn't go any higher because I'm not sure if the car is on a stock tune or what flash it may be on.
Have fun with the new ride!
Eric
