Panel Filter Testing HKS Vs Works
To answer your question more directly, if you are tuned on the edge of lean then any change you make to further lean the AFR, be it via an increase in VE or "cheating" the maf, you will risk getting into an unsafe area. If, on the other hand, you are on a safe and conservative tune, you should be fine.
The key is in having the proper monitoring equipment to allow you to keep an eye on boost, egt, and afr to name a few. Baring that, the best bet is to keep it conservative.
1. Interferance with the maf from the fans (will cause fuel trims to hunt along with the idle)
2. Higher intake air temps
Would be interesting to see, but It won't be possible for me to do that test with the other bits I have lined up, or at least it won't be comparable to a mostly stock car.
For me, it was essential to keep the stock airbox...so I went with the Works filter. It's been on the car for a few months now. I haven't dynoed the car or anything but response seems better than the stock filter element. I don't doubt it may have gained a respectable amount of hp too. It's been so long ago that I switched from the stock filter to the works so I can't really give you a good response. Car feels stronger though and it's my only mod.
www.worksevo.com is their site. and props to the OP for the test between the two drop in's
i would of gone with the works filter but got a sick deal on the K&N, but both are great brands and cant go wrong with either. i highly recommend works products currently have their springs and short shifter, both made an awesome difference.
