Evo X Plus Iveytune
Also a question for Sean, I ended up setting my redline to 7800 when I got the Ecutek tune, would 8000 be safe to run or is that about the max you would go? I've read the square engine can potentially rev higher than a 4G63 but there always seems to be a weak point somewhere, we just haven't found the limits of the 4B11. I'm assuming that with no knock and a solid tune that you can get away with the higher revs, let me know your thoughts.
We crept up on it and settled on 799x RPm as the rev limit. No ill effects so far.
The evo 10 on our dyno usually baseline in the 25x region. I have never seen one, and I have done quite a few now, dyno 270 stock, then again the car was cool so the 264 was a bit more realistic, on the high side of normal.
Chris PM me if you need more info.
Sean
Sean
This car pulls all the way to the 8000 rpm redline without any hesitation. I went to a back road that i frequent around me and lets just say last night i was going maybe 80 in certain areas and tonight i was pushing 100mph. It is faster, smoother and all around a better performing car because of Mr. Ivey's tune.
It's so funny how everyday someone says, "My X finally turned into an Evo!" What was it before??? A stock VIII wasn't real quick either.
Nice work Sean, it looks like you're the east coast premier tuner!
Sean is never disappoint anyone.
Congrats for you numbers.
11.92@113 mph.
http://www.evoxforums.com/forums/showthread.php?t=4890
