any mbc users on the x?
Old Nov 9, 2008 | 02:09 AM
SiC's Avatar
SiC
Originally Posted by SRT4 to Evox
man so I basically doooo need a tune with a mbc
was hoping to avoid it haha.
so even if its something as small as 22-23 psi guessin you still recommend tune correct?
Don't get me wrong, you'll see some increase in power, but it may not feel all that powerful.
Old Nov 9, 2008 | 09:04 AM
jmorris1027's Avatar
edit
Old Nov 9, 2008 | 09:50 AM
socalevox's Avatar
i was running a perrin MBC for a good while with no problems just dont run to much boost i had mine set like at 22-23
Old Nov 9, 2008 | 02:57 PM
RazorLab's Avatar
Originally Posted by hel_if_ino
I didn't say you were wrong... just not completely right. You said that it WILL cause a cell at part throttle, that is what I was pin pointing... see what I am saying? I am not questioning your intelligence, I am just here to tell you that I no longer experience these problems and I have an mbc, but by your statement, that is impossible.
I believe he meant without a tune, a MBC could cause a CEL because part throttle boost, etc will be higher with the MBC.
If the tuner adjusts the boost tables to compensate for this, even with a MBC, then you will be ok.
Old Nov 9, 2008 | 03:37 PM
gunzo's Avatar
No worries mate Everything is semantics ..
Old Nov 9, 2008 | 04:11 PM
switchblade906's Avatar
i run a Forge mbc and it works and looks beautifully
Old Nov 9, 2008 | 09:35 PM
Talon_66's Avatar
I run a Perrin MBC set to 26~27
Old Dec 28, 2008 | 08:53 AM
TurboGard's Avatar
I just finished installing my Forge UNOS boost controller at @ 23-24 peak. I've got a AGP cold air intake and a zchip tune and so far no codes or problems. Car runs great.
Old Dec 28, 2008 | 09:12 AM
Yearlongstorm's Avatar
I was iusing a turboXs mbc until yesterday. I went back to stock bc and got reflashed again at 23psi. It defitnely runs better with the Stock bc and I got noticable power gains. My MBC is now in my trunk lol
Old Dec 28, 2008 | 09:44 AM
TTP Engineering's Avatar
Excellent news!
Old Dec 30, 2008 | 09:30 AM
davidiii's Avatar
Agreed im going to run stock boost solenoid when i get tuned...i have perrin and although i like it, it does throw CEL wayyy to often
Old Jan 4, 2009 | 08:54 AM
David Buschur's Avatar
I run a manual boost controller on our EVO X. I can not remember if we had problems when we first installed it so I can't say for sure if you will have problems or not.
Honestly, one of the best things you can do for the EVO X is get it tuned anyway. Depending on if you want to be able to adjust the boost to different levels your best bet may just be get a custom tune and have the boost set in the ECU.
Old Jan 4, 2009 | 09:54 AM
EvoX_SA's Avatar
I have the hallman MBC on my car for about a year and have never thrown a code. Set to 24-25 peak.
Old Jan 4, 2009 | 05:17 PM
meat_EVO's Avatar
Originally Posted by gunzo
an MBC will cause a CEL at part throttle due to disagreement between the airflow and your TPS .. OR it will cause an overboost CEL at part throttle ..
i have never had any of these issues.. not being caused by the MBC atleast.
Old Jan 4, 2009 | 05:30 PM
Your maps are not stock. Gunzo is talking about an unmodified ECU map.
