Disable Day Time Running Lights using Engine Management
Canadian evo's have a DRL that is always on when driving...is there a way to disable this using some kind of engine management? ecutek etc..the DRL is shared with the headlight so disconnecting the bulb is not the answer....also pulling fuses does not work either so i believe the DRL is obviously controlled through some kind of program...so for those of you that tune has any noticed if there is a way to disable this? or is this something controlled through some other computer?
some people just like the look better
in this case its different my friend has angel eyes that he spliced into the parking lights now he just wants to drive around in the daytime with those on and no other lights
does anyone have any other ideas?
