How much power can be had?
Old Jan 14, 2009 | 11:47 AM
DueceEVO's Avatar
What kinda power numbers are being seen using the Cobb AP tune. Also I will be stock when I order the Cobb AP so what tune do I use and what kind of power can I expect from this.
Old Jan 14, 2009 | 11:56 AM
Stellar24's Avatar
Search in the Dyno Section. I just glanced but here are a couple related threads:
https://www.evolutionm.net/forums/ev...stom-tune.html
https://www.evolutionm.net/forums/ev...-modded-x.html
https://www.evolutionm.net/forums/ev...yno-sheet.html
Old Jan 14, 2009 | 12:45 PM
DueceEVO's Avatar
Which tune should i use if i just had an intake or if i was stock?
Old Jan 14, 2009 | 12:54 PM
DueceEVO's Avatar
From what i have read the tunes come loaded on the Cobb AP correct???
Old Jan 14, 2009 | 12:58 PM
witchbladeX's Avatar
Yes the maps come preloaded on the AP and youll use whatever octane level you get from the pump whether its 91 or 93. However you dont want to use an intake with the off the self maps because it will run the car too lean. Cobb I believe is going to be release a map compatible with a aftermarket intake. Heres the link https://www.evolutionm.net/forums/ev...ccessport.html
Old Jan 14, 2009 | 01:04 PM
dan@cobb's Avatar
If I recall correctly we don't have any mapping styles out as of now made for aftermarket intakes. We tried one well known brand panel filter and it leaned the car out a lot. I highly advise do not put an intake on your EvoX w/o proper tuning for it. Our Mapping is made stock intakes only.
The AccessPort does come preloaded with some mapping styles, although if you're running more modifications then what our mapping styles call for then you'll need a custom tune.
Cheers
Old Jan 14, 2009 | 02:01 PM
DueceEVO's Avatar
Hey Dan I plan to order tomorrow the Cobb AP. Can I just call and order with my credit card also about how fast can it be sent to me?
Cheers
Old Jan 16, 2009 | 04:09 PM
rdtech's Avatar
I'm pretty sure they have overnight shipping but it will be pricey.
Old Jan 17, 2009 | 04:42 AM
shankyrhodes's Avatar
used cars
It is best site to used the advertise used new cars,boats, bikes with us across the whole globe for free. do not miss this offer and same in newspaper & sites. yes you read it
right you can advertise your boats, cars, and bikes free of charge till its sold. please visit this this site again and watch the grow.
