service engine soon?
Old Mar 8, 2009 | 04:21 PM
hataeeun's Avatar
Angry service engine soon?
I got a new evo X 6 days ago, but it appears 'service engine soon' on a speedometer, i dont know why, cause I start my car up every day for over 5min and not going fast. I really worry about it, and it still ran about 400 miles
please any one answer me ~~~~~~~~~~~~~~
Old Mar 8, 2009 | 04:25 PM
redcat's Avatar
My Durango does that when my wife doesn't tighten the gas cap. Might want to check yours. It clears on its own after a few days.
Old Mar 8, 2009 | 04:26 PM
hataeeun's Avatar
it happened suddenly...
Old Mar 9, 2009 | 08:08 AM
mrMTB's Avatar
Take off the gas cap, clean the area with a paper towel and properly replace it, ensuring that you tighten it until you hear the click. Don't worry about it for a couple days (*) and it will likely go away.
* - if you want to worry when it is on, go to your local auto parts store and borrow the OBD-II scanner - pull the code, confirm it is the EVAP emissions system, and then clear it. If it is the EVAP system, it's a $50 service charge from the dealer to read and clear.
Old Mar 9, 2009 | 08:44 AM
skywalker's Avatar
As others have said take it to your local autoparts store (Autozone, Advance etc..). They have OBD-II scanners and will scan your code for free. Come back here and post the code and we can help you.
Old Mar 9, 2009 | 08:54 AM
Tunerhead's Avatar
+1
Hard to troubleshoot without knowing the code(s).
Old Mar 9, 2009 | 09:32 AM
dek0026's Avatar
it is probably the p1320 timing chain retard code. check to see if you have the latest flashes from mitsu or get an aftermarket tune.
