U0167 code?
Old Mar 27, 2009 | 09:54 AM
shyong's Avatar
Hey rob,
Might wanna look into code u0184 as well. Gotten the code after a custom tune using the ap. A member has suggested it may have to do with the ap. Please look up my thread in the stereo section. Thanks.
Old Mar 27, 2009 | 04:18 PM
jackygor's Avatar
Today I got a immobilizer malfunction code...forgot the code, but I literally could not start my car. I find that this only happens if you were to press the lock button on your key fob twice really fast. SO BEWARE! only press it once for now on the 101 maps!!
Old Mar 30, 2009 | 10:51 AM
Rob@cobbtuning's Avatar
I would venture to guess that has nothing to do with the AP, old or new maps. Would you be willing to uninstall the AP and see if the behavior is the same?
Thanks,
Old Mar 30, 2009 | 11:09 AM
Originally Posted by shyong
Hey rob,
I shot you a PM to get further details.
Thanks,
Old Jul 25, 2009 | 02:23 PM
AWDTerror's Avatar
Bringing an old thread back. I got the U0167 code today after flashing to the stage 2 +HKSPF map. Car was flashed, drove to go eat, turned the car off, locked it hitting the remote twice to honk the horn. Went inside for 30min, came back out and left for home. Didn't get the code for at least a mile driving it.
Old Mar 29, 2010 | 04:58 PM
monkey_187's Avatar
I just got this code after loading the stage 2 + HKSPF map, I reset it turned the car off, then it came back. How do you make it go away?
Old Mar 31, 2010 | 08:38 AM
HybridKOOP's Avatar
I'm getting the 0187 even with the latest firmware as of today... what gives?
Comes up as AIRBAG I believe?
Lou
Old Apr 3, 2010 | 01:06 PM
Synaptic3e's Avatar
i got this today through my accessport. I just reset ecu and it was gonzo.
Old Apr 3, 2010 | 02:22 PM
monkey_187's Avatar
I have to check mine to see if i still have the u0167 code, i also have the latest software for it.
Old Apr 12, 2010 | 08:12 PM
jackfrog's Avatar
got this code after stage 2 HKSPF 93, tried stage 1 HKS and other maps, same issue, U0167. reset ECU, turn off the car and back on, still there.
also high idling on my MR about 1500 RPM. really need this to be fixed.
Old Apr 24, 2010 | 04:14 AM
lil'evo ralliar's Avatar
uo167 is the engine code for the key signal(anti-theft)maybe the cobb is too near of the key and block the key signal
the cobb couldnt insultated
Old Apr 26, 2010 | 08:15 AM
jackfrog's Avatar
this code still bothering me, U0167, every time i change a map, it will be there
Old Oct 26, 2010 | 04:15 PM
ice1874193's Avatar
Just got u0167 after flashing to 93 octane hks panel filter v 1.07. Have turbo xs tbe n hks panel filter n removed pill. Was this ever addressed? It turns off my asc
Old Nov 4, 2010 | 03:39 PM
steevo's Avatar
Just got this today as well, first time I ever changed a map. Went from Stage 2 HKS 93oct v106 to Stage 2 HKS 93oct LWG v107. Also, this was the first time plugging up my AP to the car after getting it back from warranty repair from Cobb. They updated the firmware from what I had.
Before I even flashed, I connected the AP, turned the IGN on, and it says can't find key. It was in my lap. What to do?!! I have cleared it for now, but it looks like most with this problem are using the HKS maps.
Old Jul 20, 2011 | 03:38 PM
ikt's Avatar
ikt
