52360016 xml update 110409
Old Apr 12, 2009 | 01:52 AM
burnings's Avatar
Hi gurus,
I have made an attempt to update some addressses in the xml due to the fact that I needed the idling map to be working on the JDM. Here are the results
1. Idling RPM vs Coolant (#1 - #9)
2. Idle Adder #1,#2
3. Target Idle #1 - #4 (dunno what it does and I stopped at #4)
I only verified that Idling RPM #1 works but the rest I cannot test as I dunno what they does.
By the way, I am thinking of moving into Maf Scaling so I need some pointers on what kind of default values are the Maf scaling having so that I can uncover the address from the hex.
Thanks!
File Type: zip
