EvoScan EvoX Datalogger now supports 2byte Boost/Load/IPW
subscribe yourself to this thread:
https://www.evolutionm.net/forums/ec...en-review.html
Yes SiC and I were looking at this for you last night, I'll add your RS model to EvoScan. It might take us a few days, if you find it elsewhere (dont think its anyway at all) let us know so we can stop working on it.
YEs it will support it in the future, I am working on it, so you can get it on special now, and free upgrade it in the future when the new software for EvoX becomes available. use it as a gps in the meantime.
How long is the special running?
thank you so much because i looked EVERYWHERE and can't find it.. i'm going out of my mind!!
pls post here once you find out, thank you!
Here's the JDM RS (2008) ROM XML & Evoscan data.xml with RS logging parameters, select JDM RS from the drop down menu. The ROM XML also has the mode23 addresses in it.
28th July 2009: EvoScan v2.6 Beta18 released!
Download EvoScan Beta18 here(registered users only. Unregistered users get your registration number from www.evoscan.com)
- Auto selects "OpenPort" cable for ecu logging when a openport cable as well as usb-serial adapter is connected.
- New USDM Mode23 Items
- New JDM Mode23 Items
- New JDM RS Mode23 Items
(thanks mrfred/SiC)
(thanks mrfred/SiC)
29th July 2009: EvoScan v2.6 Beta19 released!
Download EvoScan Beta19 here(registered users only. Unregistered users get your registration number from www.evoscan.com)
- Removed some beta testing code, logging speed increased 10 fold.
- Updated Rear02Sensor LC1AFR mode23 address for USDM EvoX and USDM RA EvoX
edit: p.s.... your mirror is pretty slow... you need some hosting?
pm me
