open port2.0 w/ evoscan
Old Jun 25, 2009 | 05:13 PM
Huge's Avatar
Question open port2.0 w/ evoscan
I just recently received my open port 2.0 cable. I've been able to use it flawlessly with ecuflash to read my ecu and to upload one of gunzo's maps.
For some reason I can't get evoscan to work. I get the message " Open port usb cable not responding".
Do I need to change settings around in evoscan for it to work? I've spent more than five hours trying everything I know, and cant get it to connect to my ECU.
Any help would be greatly appreciated.
Old Jun 25, 2009 | 05:31 PM
tephra's Avatar
what version of evoscan are you using?
Old Jun 25, 2009 | 05:39 PM
Huge's Avatar
v2.6 beta 15
Old Jun 25, 2009 | 05:40 PM
tephra's Avatar
1.41 of ecuflash?
Old Jun 25, 2009 | 05:59 PM
Huge's Avatar
Originally Posted by tephra
1.41 of ecuflash?
its 1.41.2483
Old Jun 25, 2009 | 06:10 PM
tephra's Avatar
first time you installed ecuflash? (ie have no other drivers hanging about?)
Old Jun 25, 2009 | 06:12 PM
Huge's Avatar
Yeah its the first time. I down loaded it last night.
Old Jun 25, 2009 | 06:14 PM
tephra's Avatar
vista or xp?
maybe create a support ticket with evoscan...
Old Jun 25, 2009 | 06:18 PM
Huge's Avatar
vista or xp?
Its xp, and I have no Idea what create a support ticket is. Sorry
Old Jun 25, 2009 | 06:25 PM
robh's Avatar
here you go
http://www.evoscan.org/helpdesk/
Old Jun 25, 2009 | 06:29 PM
Huge's Avatar
Originally Posted by robh
thanks
Old Jun 25, 2009 | 11:23 PM
EvoX_SA's Avatar
I received my cable tonight and have version 2.16 and it logs everything okay, but whenever I try to use the DTC I get the error.
Old Jun 26, 2009 | 09:28 AM
Huge's Avatar
Ok I tried using a different laptop. Same issue.
I'm beginning to think its a problem with the cable even though it work with ecuflash I get the same message using evoscan. " OP2 Cable not responding"
Old Jun 26, 2009 | 10:10 AM
blk-majik's Avatar
what kind of cable did you get? Where did you get the drivers from? It sounds like both evoscan and the cable work fine, but evoscan doesn't support the particular cable you have.
Old Jun 26, 2009 | 11:46 AM
Hiboost's Avatar
I had some Openport2.0 issues that seemed to have gone away after installing EvoScan b15. Does EcuFlash and EvoScan b15 both have their own version of OpenPort 2.0 drivers or dll's that they share? So far b15 has been more stable and I haven't had a lockup yet while logging.
Before I would have to remove the USB cable and see if it would recognize the OP2 in the device manager, sometimes I would have to even do reboot to get it talking again. Re-installing EcuFlash or removing OP2 from the device manager seemed to help get it working again for me.
