Ecuflash error on X
Ecuflash error on X
I have been running a modified rom for a couple of months and last night i was bored so i thought i would flash my old rom back and do some logging so i could see the difference between the 2. That flashed back fine and drove fine but logging didnt work.
So this morning i couldnt be bothered spending hours trying to get the logging going so i went to flash back my modified rom and it comes up with a ecuflash error. I cant test write, compare or do anything to my old rom or new rom. I cant even read the rom that is in there now.
The error comes up like this:
[11:42:14.055] 52370024 (149 tables) inheriting evo10base (173 tables)
[11:42:14.055] 52360018 (7 tables) inheriting 52370024 (181 tables)
[11:42:14.086] 1048576 byte image read.
[11:42:56.247] J2534 API Version: 04.04
[11:42:56.247] J2534 DLL Version: 0.50.2464 Jan 29 2009 10:58:58
[11:42:56.247] Device Firmware Version: 1.05.2463
[11:42:57.827] -- loading kernel --
[11:42:57.827] -- connecting to kernel --
[11:42:57.827] kernel get version
[11:42:58.201] ECU HW part number : 1860A933
[11:42:58.233] ECU SW part number : 1860A93300
[11:42:58.248] VIN : CZ4A-0000556
[11:42:58.248] -- unlocking ECU --
[11:42:58.248] starting session...
[11:42:58.295] requesting seed...
[11:42:58.591] interface close
[11:42:58.607] interface close
the orig rom is a 52360016. I have been running a 52360018 for a couple of months with no trouble. Please help me because the standard ROM is boring
damn, i was hoping that wasnt the case. It flashed fine when i put it back to stock, nothing out of the ordinary. But when i tried to put it back to the modified rom it wont do anything.
oooohhhhhhh now i have to live with stock boost untill its fixed
Yep Colby is the only one that can help on this one.
I can help on reflashing evo7/8/9 but I have no intricut reflashing evoX knowledge yet.
anyway, don't bother going back to stock
just log the hell out of what you have
with an AFR to start with then mod the Timing.
This might sound dumb, but do you have anything else open that could be using the interface?
EvoScan, PCMScan, etc?
I recall a while back I was getting a similar error log, I think I just closed everything and it worked fine.
Generally the problem is much more complicated, but I thought I'd throw this out in case it was a simple fix.
i tried the evoX recovery info off openecu.org but that doesnt work either.it comes up with this instead:
[15:45:20.054] J2534 API Version: 04.04
[15:45:20.054] J2534 DLL Version: 0.50.2464 Jan 29 2009 10:58:58
[15:45:20.054] Device Firmware Version: 1.05.2463
[15:45:27.391] sending init sequence 1 (0001)
[15:45:30.698] sending init sequence 1 (0003)
[15:45:34.005] sending init sequence 1 (FFFF)
[15:45:37.312] sending init sequence 1 (F0F0)
[15:45:40.058] no response to any known code
[15:45:40.058] interface close
The car still runs which is a good thing, but it has the 'boring factory' tune rather than my one
i sent a email to tactrix so hopefully ill get a reply soon Thread
BlackHawk_Tsi
Apr 20, 2015 04:25 PM
