Torque limiter #1-#4 in ECUflash for EVO X MR
Old Jul 6, 2009 | 11:35 PM
nj1266's Avatar
Originally Posted by Hiboost
"Airflow Check #4" and the "Torque Limiter #4" tables are somewhat of a mystery and you shouldn't need to adjust them. I ended up experimenting with keeping the 60.4% column at 250 limits from 3500 - 8000 and interpolating the 50.2% column towards the 40% column, so far no error codes have resulted and I'm not sure it was necessary.
Hope that helps!
From what I understand, it is airflow and torque table #4 that should be modified and the other 3 left alone. You are saying the opposite
Old Jul 7, 2009 | 12:46 AM
tephra's Avatar
Originally Posted by Ray Knight
Ok just picked up the car and it's exactly the same as when i dropped it off
The codes are as follows:
P1870 and P0725
They have no idea what it is. My car is hardly drivable
Anyone have any ideas?
DTC P1870: engine torque signal abnormality.
DTC P0725: engine speed signal abnormality.
Old Jul 7, 2009 | 02:21 PM
Clipse3GT's Avatar
Call up BR, and ask them to get you a map with adjusted Torque and Air Maps...
Old Jul 7, 2009 | 06:04 PM
Ray Knight's Avatar
No need to call. He's already on it! Talk about support The guy is really good about making sure all of his customers are running smooth
Old Jul 7, 2009 | 06:54 PM
Hiboost's Avatar
Well I'm going somewhat by looking at the changes the EcuTek tune did to my car compared to stock. The #4 tables were untouched although that doesn't mean it's the only way to do it.
Leave table #4 alone .. you can change the torque limit tables without changing any thing else ..
Plus Gunzo said leave them alone! haha
Old Jul 7, 2009 | 07:02 PM
PR_Mivec's Avatar
will this also apply to gsr?
i think i have the same problem but not those codes in particular...
Old Jul 7, 2009 | 07:08 PM
Hiboost's Avatar
Yeah if you are making more part throttle boost from a MBC in a GSR or MR it will also help you avoid limp modes.
Old Jul 7, 2009 | 07:21 PM
PR_Mivec's Avatar
excellent thx!
Old Jul 8, 2009 | 10:18 AM
617G's Avatar
subscribed...excellent information in this thread regarding tq table limits
Old Jul 8, 2009 | 11:10 PM
PR_Mivec's Avatar
worked great for me! thx!
Hiboost you got PM
Old Jul 8, 2009 | 11:21 PM
nj1266's Avatar
If Gunzo said to leave #4 alone, then why do his maps have #4 changed and #1 through #3 stock. Check the maps he posted in the EvoXforum. What you are saying is not reflected in his maps.
Old Jul 8, 2009 | 11:35 PM
Hiboost's Avatar
It could be there is more than one way to skin a cat then, perhaps Gunzo or others can chime in on what all these limits tables specifically come into play?
Old Jul 8, 2009 | 11:42 PM
gunzo's Avatar
Nope .. those values are off the MRs .. there's no point changing these maps .. doesn't do anything AFAIK for now
Your primary concern is map #2 and #3 .. I can only trigger #1 under certain conditions which I'm still trying to figure out ..
Old Jul 9, 2009 | 12:08 AM
nj1266's Avatar
I downloaded the GSR map that you posted and it has #4 airflow/torque changed. 1 through 3 are unchanged.
So what are you saying NOW? Are you saying that the changes in #4 in the GSR map mean nothing? Why did you change the numbers in #4 in the GSR map if they mean nothing?
Old Jul 9, 2009 | 12:19 AM
Clipse3GT's Avatar
Yeah, I started tripping the p1235 once I put on the ETS 4" FMIC. I used to trip the 1241 before, however I adjusted the Airflow & Torque Limits, not it seems I need to adjust the limits again more.
I only get the p1235 in 5th gear on the highway, boost spikes to about 26 psi. I am tuned for 25psi. Grr...
So map limits 2 & 3 are the most important ones it seems or who ever said on this thread. Do maps 2 & 3 can look the same?
