Latency & Scaling for DW 800cc for COBB AP???
Old Jul 16, 2009 | 11:44 PM
Clipse3GT's Avatar
I searched but I did not find anything for the COBB AP in specific as far as the scaling goes for the DW 800cc injectors. If anyone has some knowledge, as to what to set the scaling and latency in RACE (Cobb Software). Please post.
Thanks everyone!
Old Jul 16, 2009 | 11:51 PM
HB Speed's Avatar
i posted them lemmie look
Old Jul 17, 2009 | 12:03 AM
Clipse3GT's Avatar
Thanks!!!
Old Jul 17, 2009 | 01:17 AM
HB Speed's Avatar
p00f
Old Jul 17, 2009 | 01:49 AM
Clipse3GT's Avatar
p00f
Thank you, sir. E-rep.
I did not see a option for Batt. Vol. in COBB RACE, so I assume you just change the injector rate. Yes?
Old Jul 17, 2009 | 02:01 PM
ScottSpeed21's Avatar
In AccessTuner Race, it's the Injector Latency table. Volts on top, Duty Cycle on the bottom.
Old Jul 17, 2009 | 10:52 PM
Clipse3GT's Avatar
Thank you!!!
Old Jul 19, 2009 | 09:19 AM
criptballer's Avatar
this would work the same on ecuflash right?
Old Jul 19, 2009 | 09:51 AM
Right. The Ecuflash and ATR tables are identical.
Old Jul 19, 2009 | 03:30 PM
isn't 80% of 800, 640? i thought thats the percentage that we were suppose to be at?....
Old Jul 19, 2009 | 08:48 PM
Clipse3GT's Avatar
Max typically can be 90% IDC.
Old Jul 20, 2009 | 02:58 PM
is there a way to double check if this is the proper scaling once i install them?
Old Jul 20, 2009 | 03:04 PM
GST Motorsports's Avatar
Log fuel trims
Old Jul 20, 2009 | 05:49 PM
Clipse3GT's Avatar
Just got these installed today, took about 30 min taking it slow and double checking. Will see how everything works out with them.
Old Jul 20, 2009 | 06:03 PM
nj1266's Avatar
and make sure they do not drift more than +/-5%. If they do, then adjust scaling/latency to bring them in check.
