Intakes, Fuel Trims, and AFR
Old Aug 2, 2009 | 02:50 AM
tephra's Avatar
Well thats the exact question.
Some say OL does use the FT's - some say not.
I havn't had time to confirm either way...
Old Aug 2, 2009 | 08:18 AM
nj1266's Avatar
Originally Posted by fostytou
Seriously guys... before you get into LTFT closed loop theory, make sure the corrections actually apply. Did everybody just glaze over my post because you want to believe the worst?
You are wrong. I am not saying that LTFT cruise is ACTIVE during WOT. I am saying that LTFT cruise CARRIES over to WOT operation. It did it on my Evo 9 and it does it on the Subarus and it does it on the Evo 10.
Here is a test I conducted yesterday:
Today Gear Grinder and I conducted multiple tests on his Evo X. One of the was to confirm, yet again, the impact of LTFTs on the AFR using the famous CARB legal intake.
We flashed the car back to the stock 020 rom id when the trims were at +6.4%. They went to 7% by the time we logged. We ran two back to back WOT 4th gear runs.
Then we ran the car at a steady 60 mph on the freeway and headed back to the same on-ramp that we did the first two logs. By the time we got to the on ramp, the LTFT was maxxed out @ 12.5%. We did 2 back-to-back WOT logs
Here are the results, confirming the previous results
The AFR became richer when the trim went up from +7% to +12.5%. At 6500 rpm the AFR richened up from 11.05:1 to 10.6:1, 0.45 of a point richer. The math supports the findings: the trim rose 5.5%. 11.05x0.055=0.6-11.05=10.45. 10.45:1 is very close to the 10.6:1 that we logged when the trims maxxed out at 12.5%.
So now it is confirmed that the famous CARB legal intake can max out the LTFT at 12.5%. It can even trigger a P0171, system too lean code as it has done on some cars running in CA.
Old Aug 2, 2009 | 08:24 AM
nj1266's Avatar
Originally Posted by BigT
open loop does not utilize the fuel trims. It just throws as much fuel in as the ecu thinks it needs. However, intake temp and coolant temp also play a role in this.
Wrong. I have confirmed it multiple times on different cars. LTFT cruise carries over to open loop operation. I first encountered this when I was tuning my Evo 9. Everyone was saying it does not, only one person said it does. He was right. Here is the htread. It is long. I was going nuts trying to fix it.
https://www.evolutionm.net/forums/ec...ight=funky+afr
Old Aug 2, 2009 | 08:25 AM
nj1266's Avatar
I have...Those who say it does not are wrong...It does...The Subie guys are well aware of this...They are way ahead of us on this issue.
Old Aug 2, 2009 | 08:30 AM
jpierson77's Avatar
Just logged my LTFT cruise, im pegged at 12.5% idle is 4.6%. Looking through ecu flash looks like we do not have access to the MAF scaling map yet is that correct? Is adjusting the latency really the proper way to fix this as the root of the problem is likely the intake? Even if the LTFT is not used at wot shouldnt we still try to get that LTFT cruise back to within the 5% range simply as a fail safe in case we get into a situation where the car may need extra fueling. If mine is maxed at 12.5% the ecu can not richen any further correct?
Old Aug 2, 2009 | 08:36 AM
nj1266's Avatar
We do not have the MAF scaling map in ECUflash. Adjusting the latency or scaling is the one way that I know of to fix this. The best way is the MAF, but we do not have the table yet. I have learned that there is more than one way to do the same thing.
Don't let anyone tell you that LTFT do not carry over into WOT. They are WRONG, dead wrong.
When pegged at 12.5%, then the ECU can no longer add fuel to correct what it sees as a lean condition during cruising. If this continues a P0171 "system too lean" is triggered.
Old Aug 2, 2009 | 09:00 AM
tephra's Avatar
well i have never seen LTFT-High get off 0% (on CT9A)
And that would be the MAF-Hz bin for most WOT operation...
I havn't really logged the trims on the X yet due to stock injectors - i'll go have a look tommorow.
ps - Subaru != Mitsu
ps2 - MAF Scaling is out there, I have it defined on my ROM and I have seen it defined on USDM ROM's
for 53040010:
Code:
	<table name="MAF Scaling Part 1" address="5753e">
		<table name="Volts" address="61626"/>
	</table>
	<table name="MAF Scaling Part 2" address="57596">
		<table name="Volts" address="6167e"/>
	</table>
	<table name="MAF Scaling Part 3" address="575ee">
		<table name="Volts" address="616d6"/>
	</table>
5268XXXX
Code:
    <table name="MAF Scaling Part 1" address="5753a">
        <table name="Volts" address="615ea"/>
    </table>
    <table name="MAF Scaling Part 2" address="57592">
        <table name="Volts" address="61642"/>
    </table>
    <table name="MAF Scaling Part 3" address="575ea">
        <table name="Volts" address="6169a"/>
    </table>
Old Aug 2, 2009 | 09:02 AM
tephra's Avatar
oh one Q for you - how does the ECU even calculate the FuelTrim for WOT?
given WOT = closed loop = !stoich = NB 02 sensors useless
Old Aug 2, 2009 | 09:14 AM
nj1266's Avatar
It does not...It just carries over from closed loop cruise into WOT operation. So even though the LTFT cruise is not adding/subtracting fuel at WOT, it adds/aubtracts the fuel it has calculated in closed loop to WOT. So if LTFT cruise is X, then the AFR becomes, target AFR+X. X stays the same in WOT operation as it was during closed loop cruise. It is simply added to the target AFR.
Old Aug 2, 2009 | 09:23 AM
nj1266's Avatar
for 53040010:
Code:
    </table>
    </table>
    </table>
5268XXXX
Code:
    </table>
    </table>
    </table>
Thanks for the tables. You are a gem
I have tested the Evo IX, Subrau STI, Subaru WRX, Evo X and all of them CARRY the LTFT-cruise over to WOT operation. The LTFT cruise is NOT active at WOT, it is just added (carried over) to whatever the target AFR is in the fuel table.
Old Aug 2, 2009 | 09:48 AM
fostytou's Avatar
EvoM Community Team
Originally Posted by nj1266
You are wrong.
I am wrong to ask a question?
Your testing seems reasonable, but still leaves quite a few things open on the table. I'm not saying it is wrong, I'm just saying it might not be end all be all conclusive.
Do we know if the X has any lean spool equivalent? That could seriously play a part in your testing and be very unpredictable in relation to how you were driving before testing each pull.
I appreciate what you have done so far, but it is only a step in the right direction...
I did take a look at a few older logs and noticed that 200+ load is achievable with <1580hz on the IX in the lower RPMs. This still leaves the question (for me, at least) if FT applies during open loop operation or if that *only* turns off the trim feedback. I still need to do some logging of my own to see if this stuff applies to my car as I think it does.
A good positive solution to this problem would also be to find the fuel trim airflow hz switchover point and lower it significantly. If I remember correctly these values were just before the fuel table in the IX.
Old Aug 2, 2009 | 12:17 PM
BigT's Avatar
Thanks for the clarification, NJ.
Old Aug 2, 2009 | 12:59 PM
tokeone's Avatar
since maf scaling is available, does that mean that this could be remedied easier without all the fuel trim changes?
Old Aug 2, 2009 | 01:01 PM
jpierson77's Avatar
So little help with the MAF tables. I just need to copy the code given into my rom correct?
Old Aug 2, 2009 | 01:41 PM
nj1266's Avatar
[quote=fostytou;7348774]
There is no lean spool on the Evo X. It is turned off from the factory.
LTFT cruise is NOT active during WOT. The LTFT does not add/subtract fuel when in WOT. What happens is the LTFT cruise that has already been stored is added to WOT operation.
I do not know why it is done that way. I do not know why the ECU does not simply read what is in the fuel map w/o adding LTFT cruise to the fuel map.
