Pulling DTC codes: any option other than PCM Scan?
Old Aug 1, 2009 | 11:24 AM
blk-majik's Avatar
Does any of the other software support pulling DTC codes on the X? I heard it works with the free version, but when I try it says this feature only works in the full version. I'd rather not buy it just to pull codes.
Thanks!
Old Aug 2, 2009 | 07:29 AM
jpierson77's Avatar
$50 at autozone got me a pocket scanner, reads and clears perfectly.
Old Aug 3, 2009 | 02:46 PM
blk-majik's Avatar
thanks jp! I should have clarified that I'm looking for software options that will work with the tactrix openport 2.0 cables. I kinda assume that as the default premise at this point sorry!
A bit of background as to why: I'm starting an in-dash touchscreen carputer project. It'll do all the typical stuff like gps, mp3, dvd, internet (via cellphone tether), etc. Advanced stuff I want to work in later: on-board camera recording, track GPS map support with lap time calculator and sensor logging. And some tuning options: ecuflash and evoscan. The only thing I'm missing is the ability to pull DTCs. I could just buy PCMScan, but then I'm paying $100 for just 1 feature, since Evoscan does the rest already. So I'm just looking for any other more reasonable (free would be nice!) software alternatives.
Old Aug 3, 2009 | 03:31 PM
nonschlont's Avatar
u should be able to use evoscan 2.5 or later. DTC...
Old Aug 3, 2009 | 09:06 PM
blk-majik's Avatar
I was under the impression that pulling DTCs didn't work on the X yet? And I tried I tried with the various methods and never got any results (while the CEL was on). Anything I could be overlooking?
Old Aug 4, 2009 | 07:08 PM
Excalibur's Avatar
Did not know. Thanks.
Old Aug 4, 2009 | 08:31 PM
xPRimNT's Avatar
Nope, DTC pulling for the X is not yet in EvoScan. The 8s and 9s are fine, but no X.
You can clear with ECUFlash though!
I've been using PCMScan, so I can't offer anything! Sorry...
Old Aug 5, 2009 | 11:26 PM
blk-majik's Avatar
So we're stuck with buying PCMScan if we want to pull codes for now? Is there a way to be able to pull the code in the demo or not? I've heard you could, but the demo I have sure doesn't work.
Old Aug 6, 2009 | 12:44 PM
bbarnhill's Avatar
I REALLY need this feature in evoscan to read codes ... I threw a code today and am going to have to go to autozone to have them read it ... I feel like a retard being able to log but not read DTCs.
Old Aug 6, 2009 | 12:50 PM
newcomer81's Avatar
PCMScan work with the OP2 cable?
Old Aug 6, 2009 | 01:02 PM
nonschlont's Avatar
My Bad! I apologize on that, I completely missed, that you have a X...
Old Aug 7, 2009 | 04:57 PM
blk-majik's Avatar
An old trick i remembered: if you jumper pins 4 and 9 of the ODB2 port together, then turn the car on, it should cause the CEL light to flash instead of stay solid. The flashing pattern should indicate a 2-digit number: first digit in long flashes, 2nd digit in short flashes. You can use that pattern to look up most basic codes. I haven't tried it on the X yet, but if anyone wants to give it a go, it could work as a poor mans CEL reader
Old Aug 7, 2009 | 05:55 PM
Excalibur's Avatar
Do you have a link to the one you got?
Old Sep 10, 2009 | 07:27 AM
Tractionlimit's Avatar
+1 Same here. Has there been any update on whether EvoScan will get this functionality?
Old Sep 10, 2009 | 02:51 PM
Excalibur's Avatar
I wish someone would get on here and give us some reassurance that it will gain that function eventually.
