Logging Wideband AFR via Rear O2 ECU ADC Input
Old Aug 24, 2009 | 09:01 PM
xPRimNT's Avatar
Ok, so I'm actually doing this right now.
I ran out of daylight, so I'll finish the actual wiring tomorrow.
I have a HowTo coming with pictures as well, if anybody is interested.
Old Aug 24, 2009 | 11:27 PM
stokEd's Avatar
Thumbs up
Excellent, report back when you've got it together.
I had to put this on hold until I tracked down a boost leak. Just figured it out tonight: leaking Diverter Valve. Solution: took the thing out, flipped it then reversed it (just like that Missy Elliott song...lol.)
Old Aug 25, 2009 | 06:18 AM
coevolve's Avatar
If I understand this correctly, you are disabling the rear 02 sensor to convert it's input (yellow wire) into the ecu for evoscan...
Are you welding a new bung for the WB onto the DP and plugging the rear 02 bung?
Old Aug 25, 2009 | 07:46 AM
xPRimNT's Avatar
How did you figure out that you had a leak? Stock BPV?
That's the gist of it!
I have a test pipe, so instead off putting the rear O2 sensor in the bung, I put the WB sensor. I'll have many more details soon.
Old Aug 25, 2009 | 07:50 AM
gsrboi80's Avatar
Doing this on my CT9A I still have the rear O2 connected though as it still needs to see the heater circuit or it will chuck a CEL.
My NGK works awesome this way have been logging for over a year like that
Old Aug 25, 2009 | 08:32 AM
stokEd's Avatar
Do you have P-bit disabled in EcuFlash?
Old Aug 25, 2009 | 08:47 AM
gsrboi80's Avatar
Yup rear O2 disabled in P-BIT, WB pinned directly to ECU and EVOSCAN xml modded with widebands operating range formula
Old Aug 25, 2009 | 10:12 AM
stokEd's Avatar
Great, thank you.
Old Aug 25, 2009 | 09:25 PM
xPRimNT's Avatar
Installed
I'll test logging and get the HowTo up tomorrow.
(Man that harness is hard to get to)
Old Aug 26, 2009 | 09:43 AM
xPRimNT's Avatar
Tephra, will logging the ADC at that address slow down the other Mode23 items? Or is there a Mode23 address for ADC (if it isn't already)?
Old Aug 26, 2009 | 04:01 PM
tephra's Avatar
yeh the more things you log the slower they all go.
what u logging now?
Old Aug 26, 2009 | 04:43 PM
xPRimNT's Avatar
Damn, I may need to get in touch with you about the address.
And I know the more things you log the slower it goes, I was just wondering if the address you mentioned was "Mode23".
The address isn't yet working for me. I'll try a few more things and then cry for help. Would you mind double checking the address for 52680020?
Old Aug 26, 2009 | 05:39 PM
tephra's Avatar
Originally Posted by tephra
0x80834E - it's 2byte
Its a memory address, if you want the requestid for evoscan, it will be something like 0x2380834E, make sure you set ResponseBytes="2"
Old Aug 26, 2009 | 07:55 PM
xPRimNT's Avatar
^ Figured it out. The address was wrong. I'll have all the details up in a bit.
Old Aug 26, 2009 | 07:56 PM
tephra's Avatar
what my address was wrong?
