Low Timing and hesitation during cold start
Old Aug 23, 2009 | 10:00 PM
tephra's Avatar
mine is exactly how GST posted...
Keep in mind it is a percentage for interpolation to the coldstart maps.. not a % of the actual timing value...
Old Aug 23, 2009 | 10:21 PM
Hiboost's Avatar
Hmm mine looks like this:
-40 0%
-40 100%
-40 100%
-40 100%
-40 100%
-40 0%
-40 0%
-40 0%
Not sure if it is worth testing still, I would rather find the right table before mucking with unknown values.
As far as percentage for interpolation that is confusing me a bit.
If (42*)+ (-30*) = 12* at 100%, what would 50% or 25% be then?
Old Aug 23, 2009 | 10:38 PM
tephra's Avatar
oops - axis updated in post above...
Old Aug 23, 2009 | 11:28 PM
billedoc's Avatar
hmm good thread, im sub'd to this thread
Old Aug 23, 2009 | 11:31 PM
Hiboost's Avatar
That works, will test on my next cold start!
Old Aug 24, 2009 | 12:21 AM
SiC's Avatar
SiC
I had the same problem after changing injectors/cams. I just learned how to drive avoiding this RPM/load area when the engine was cold I'll test this out and see how it goes.
Old Aug 24, 2009 | 07:08 AM
coevolve's Avatar
great work guys....subscribed
Old Aug 24, 2009 | 07:56 AM
Hiboost's Avatar
Drum roll...
The car had a wonderfull 40* timing during cold start and was driving SMOOTH as ever just like it was fully warmed up. Thanks Tephra and GST for pin pointing this so quickly!
The only thing is Mitsu may have placed that there to warm the cat for emmissions purposes so anyone still running one may want to try reducing the use of the tables only partially to see if there is balance between smoothness and heating up the cat on cold starts.
Old Aug 24, 2009 | 08:02 AM
tephra's Avatar
Did you just reduce the % in that little table?
I will probably just make 34 degC like 75% and 50 degC like 0%...
So I will still have cold start, but just for shorter time...
Old Aug 24, 2009 | 08:16 AM
coevolve's Avatar
hiboost/tephra can you give a comprehensive review of what you did? (not comprehensive in length necessarily)
What .xml code did you use?
Which map?
What changes...etc
Thanks guys, awesome work!!!
Old Aug 24, 2009 | 08:18 AM
Hiboost's Avatar
I went to 0% for now and will add some retard back for the colder weather that will eventually bear down on New York State. There is probably a happy medium ground for percentages that will work for colder weather.
What looks odd to me though is the retard was kicking in at 120-140 F coolant temps but according to the chart it should only have kicked in that table from 18 F to 93 F for 100% and then tapered to 0% by 122 F.
-32 C = -26 F
-8 C = 18 F
7 C = 45 F
20 C = 68 F
34 C = 93 F
50 C = 122 F
62 C = 144 F
77 C = 171 F
Which map?
What changes...etc
I'll post some screenshots after work unless Tephra beats me to it, everything you would need is in the posts though.
Old Aug 24, 2009 | 10:35 AM
GST Motorsports's Avatar
Originally Posted by Hiboost
Drum roll...
Awesome, glad tephra could find it so quickly.
This will help a ton when you get cams as well as they make the cold starts worse with the timing retard.
Old Aug 24, 2009 | 10:56 AM
coevolve's Avatar
-32 C = -26 F
-8 C = 18 F
7 C = 45 F
20 C = 68 F
34 C = 93 F
50 C = 122 F
62 C = 144 F
77 C = 171 F
Thanks man. The "axis" change post was the only thing that confused me a bit...
screenshots would be awesome. When did you start experiencing this low throttle condition? My X is stock save the tuning that i've been learning. My current part throttle is quite fine.
Old Aug 24, 2009 | 11:50 AM
Ok here is the table:
and here is the code used for getting it:
evo10base.xml:
<scaling name="Percent255" units="%" toexpr="100*x/255" frexpr="255*x/100" format="%.0f" min="0" max="100" inc="1" storagetype="uint8" endian="big"/>
<table name="Percent Low Temp Timing Trim vs Coolant Temp" category="Timing" type="2D" level="2" scaling="Percent255">
<table name="Engine Temp" type="Y Axis" elements="8" scaling="Temp"/>
</table>
52680015:
<table name="Percent Low Temp Timing Trim vs Coolant Temp" address="56170">
<table name="Engine Temp" address="610e0"/>
</table>
A big thanks to Tephra.
Old Aug 24, 2009 | 03:59 PM
tephra's Avatar
no problemo
