limp mode
Old Aug 24, 2009 | 05:08 AM
Rainwarrior's Avatar
limp mode
problem with my x always goes in to the limp mode when the boost hit only 0.3 bar
Old Aug 24, 2009 | 05:19 AM
Hiboost's Avatar
Have you adjusted the Airflow and Torque Limits tables? Assuming yes you have likely increased the lower RPM limits too high so that the car actually flags you as being less airflow than expected. The numbers in the tables are expected load percents and allow a certain range higher and lower than the number you enter.
