Any Tuner can read my log and tell me ?
Old Aug 24, 2009 | 11:38 AM
grafix143's Avatar
Hi,
I created my self a map for evo EDM GSR
with AMS turbo back and also HKS drop in filter
and this is my log , cam anyone confirm if its safe or no ?
using cobb ap
File Type: zip
Old Aug 24, 2009 | 02:18 PM
LaXGSR's Avatar
You need to log fewer parameters to get decent logging speed. You only have 1 sample per second which is useless. Ideally, you should have at least one sample every 250 rpm's during a WOT third gear log. Also, some of your logging parameters look like they might not be defined correctly (values look odd). Try logging the basics like loadfuel, timing, boost, afr, knock sum, etc.
Old Aug 24, 2009 | 10:09 PM
grafix143's Avatar
ok i will do
