GM solenoid question
Old Oct 6, 2009 | 12:32 PM
cnj4ever's Avatar
If you swap the solenoids out STOCK vs GM boost solenoid, do you have to retune for that or is it a straight drop in affair. Thanks for the help sorry if this has already been answered somewhere else.
Old Oct 6, 2009 | 12:33 PM
617G's Avatar
yes, it has to be retuned! The are no longer any restrictor pills and you will overboost untuned.
Old Oct 6, 2009 | 01:42 PM
goofygrin's Avatar
more than just the overboost, you only use one table to control the boost and the changes are finer.
Old Oct 6, 2009 | 11:44 PM
tephra's Avatar
yes retune DEFINITLEY required.. otherwise you WILL blow your engine!
Old Oct 7, 2009 | 01:53 PM
KevinD's Avatar
RETUNE!!! you have to reduce the duty cycle on the boost control solenoid tables. default it is 100, start at 50 with a 3 port.
