Cobb AP can only read up to 22.3 psi correct?
Old Oct 20, 2009 | 03:11 PM
dragon831's Avatar
Cobb AP can only read up to 22.3 psi correct? and you better say yes!
Old Oct 20, 2009 | 03:36 PM
AWDTerror's Avatar
no
Old Oct 20, 2009 | 04:10 PM
HR2L's Avatar
negative...
Old Oct 20, 2009 | 05:39 PM
dragon831's Avatar
that sheet aint funny!! lol .. well... whether i do a pull in 2nd, or in 3rd, the highest reading it gives is 22.3. Don't tell me that means I have a leak? I updated the AP to see it the boost reading would work. The "rel boost" is the boost right? also i was tuned peaking 26.5.
Old Oct 20, 2009 | 06:35 PM
wwevo8's Avatar
when i had my mazda speed 3 with a cobb ap i was showing 24 psi
Old Oct 20, 2009 | 07:05 PM
kenpo1441's Avatar
You were boosting 24psi on a speed 3 motor? I don't think my speed 6 ever went over 16 psi.
Old Oct 20, 2009 | 08:58 PM
wwevo8's Avatar
lol yea i was fully bolted and running a stage 2 map from cobb that would spike 24 hold 22. the turbo seals went out like 3k miles later and was going to replace it with a reworked ko4 but i got state ref and had to part out then sold it and got an evo!!!!
Old Oct 21, 2009 | 02:02 PM
chase123's Avatar
It used to max out a while back. It was fixed in an update. Try updating.
Old Oct 21, 2009 | 03:33 PM
dragon831's Avatar
my ap firmware is v1.3.2.2 - 11209 .... what's the 2nd set of numbers for? jan 12 09?
Old Oct 22, 2009 | 04:49 PM
COBB Tuning's Avatar
You need to update your AccessPORT. We have some pretty major updates for the AccessPORT currently available that address a few issues, like the boost etc. Just run your "Updater" program and it should update itself to the latest version and then update your AccessPORT and dongle.
Travis
COBB Tuning
Old Oct 23, 2009 | 02:10 PM
raytrix's Avatar
That's funny, my Greddy Informeter says the same thing. It only reads the manifold pressure up to 22.3 psi. I never peaked over that in either stock tune, stage 1 HKS Cobb AP map, or stage 2 HKS Cobb AP map. I didn't try reading off the Cobb AP device yet. I wonder if my Greddy Informeter is limited or the Evo X stock manifold pressure sensor can't read beyond that.
Old Nov 28, 2011 | 06:46 AM
hackerrei's Avatar
Psi
The informeter can only read higher boost with the added sensor for boost.
The cobb app can read upto or above 30psi just update the firmware.
t3am 83rd
Cobb AccessPORT
Apr 28, 2016 08:16 AM
420a-t
Dec 21, 2014 11:12 AM
hachansoo0413
Jul 25, 2012 10:10 PM
Walt
Jun 25, 2009 05:41 AM
2006EBPIX
22
Jan 17, 2007 03:42 PM
