Question about COBB AP Maps
Old Oct 23, 2009 | 04:12 PM
Hakmeister's Avatar
seems that for the cold air intakes they don't have any maps? or maybe they are mislabeled.
i planned on buying a injen cold air intake and currently have AP, which one would work for my mr?:
"Stage1+SF for Stock Vehicles with Injen intake system. 91 Octane fuel. +18% HP / +6.7% lb. ft."
"Stage1+SF for Stock Vehicles with Injen intake system. 93 Octane fuel. +19.3% HP / +9% lb. ft."
"Stage1+SF for Stock Vehicles with Injen intake system designed specifically for for AZ/CA/NV 91 Octane. +18% HP / +6.7% lb. ft."
I live in cali.
same thing with ams maps?
Old Oct 23, 2009 | 06:32 PM
ScottSpeed21's Avatar
If you have an Injen intake you use the map for the Injen intake.
If you're running 91 Octane, you run the 91 Octane map
If you're running 93 Octane, you run the 93 Octane map
If you're running 91 Octane from AZ, CA, or NV, you use the AZ/CA/NV 91 Octane map
I thought it was all pretty self explanatory...
Old Oct 23, 2009 | 11:24 PM
Hakmeister's Avatar
the question was, will they work for both short ram and cold air
Old Oct 24, 2009 | 06:48 AM
-H-'s Avatar
-H-
I would assume the maps would work fine whether it's a cold air or a short ram intake. The maps are pretty conservative to begin with and the only real difference is going to be the intake air temperature. Try it and see. You can always tweak the maps if you need to change something.
Old Oct 24, 2009 | 07:52 PM
Yes
Ron burgandy
92
Jul 16, 2012 05:12 AM
most wanted
Oct 27, 2009 12:48 AM
purebredmutt
Mar 27, 2009 07:41 PM
deadbeatrec
Feb 16, 2008 05:48 AM
