Using ecuflash got a check engine?
Old Oct 27, 2009 | 05:08 PM
jrsimon27's Avatar
hi guys i downloaded my stock rom using ecuflash the car checks a lot of stuff while reading the rom then when finish it says to turn off your ignition
well after reading the ecu a check engine light remained on it had 2 codes
1-said the ecu got disconnected
2-this code cant remember it but it had something to do with the gearbox?
why did this happened? could it be cause i didnt write back the stock rom to the ecu?
how can i change my revlimiter it has 2 one which says rev limiter on and rev limiter off which of the both do i touch if i wanna put it at 8000rpms?
thanks guys
Old Oct 27, 2009 | 05:39 PM
xPRimNT's Avatar
If you have an MR, you have to Clear DTC Codes before you're done.
It's nothing "wrong".
Old Oct 27, 2009 | 05:50 PM
jrsimon27's Avatar
oh ok thanks budddy
Old Nov 24, 2009 | 06:28 AM
saimike's Avatar
hey guys, i can't seem to find the "clear dtc" menu item on ecuflash, got the latest ver
Old Nov 24, 2009 | 08:30 AM
Whitewind's Avatar
Read your ECU first then go ECU drop menu and you will see it. But must read ECU first.
senate6268
Lancer Engine Management / Tuning Forums
272
Jun 25, 2024 08:27 AM
nuk1ear
Nov 27, 2016 05:13 PM
ziad
Mar 2, 2016 02:26 AM
jgesler
May 24, 2013 05:02 AM
bleunetizen
Feb 20, 2011 01:19 PM
