Help! COBB & ARC~~~~~~
Old Nov 5, 2009 | 06:33 PM
boyuan88's Avatar
I have ARC intake pipe, ARC air box, Greddy exhaust and HKS bolw off in my evo x. Does someone know can I use COBB AccessPORT? Which map I should downloard?
THX~~~~~~~~~~~
Old Nov 5, 2009 | 07:57 PM
mrMTB's Avatar
Replace the HKS BOV with the stock, and use the Stage I + HKS map. (unless you have a downpipe and HFC on your exhaust, in which case you should remove the boost pill - still replacing the BOV - and use the stage II w/ HKS map)
Old Nov 5, 2009 | 07:58 PM
buchnerj's Avatar
^+1, get rid of the HKS, unless your raising the boost the stock one should do just fine.
Old Nov 5, 2009 | 08:01 PM
UT_Evo's Avatar
But what if I want that cool shwoomp woosh sound?!
Old Nov 5, 2009 | 08:58 PM
boyuan88's Avatar
I have a greddy downpipe~~~~ Is that ok?
Old Nov 5, 2009 | 09:11 PM
boyuan88's Avatar
I can get rid of the HKS blow off, should change to other blow off or just use original one?
I had come through 3 times engine just like shut down on highway when I over 130km/h more than 1 hour or 160km/h 30mins. Than I have to cool down the car than restart, but will show check engine light. Have you seen this problem?
Old Nov 6, 2009 | 01:44 AM
ganghyung's Avatar
Get O2 wideband for safety!
