Cobb Stage 2, TBE, Drop in and UICP?
Old Nov 28, 2009 | 08:14 PM
Methodical4u's Avatar
Just wondering if those 3 mods would be a bit to much for Cobb's stage 2 map with the HKS drop in map (using green filter though)? I would eventually get an over the net tune with someone, but for a while would it be ok?
Old Nov 28, 2009 | 08:38 PM
Clark_Kent's Avatar
Ask Mellon, Ask Cobb.
Old Nov 28, 2009 | 08:46 PM
well yeah, that's why I put it on a forum... so Cobb could tell me. Mellon can't tell me... he's a custom tuner and unless he looks over the stage 2 map.
Old Nov 28, 2009 | 09:03 PM
steven88's Avatar
i heard the UICP you will have no problems....search for UICP and you'll see a few threads come up in regards to the cobb AP
Old Nov 28, 2009 | 09:38 PM
Tunerhead's Avatar
I'm running this similar setup with no issues.
Old Nov 28, 2009 | 09:50 PM
evo unknown's Avatar
In my VIII, I am running the stg 2 mods + uicp and licp. It does not effect drivability at all, but I am not getting the full benefit from the parts without a custom tune.
Old Nov 28, 2009 | 11:34 PM
UT_EvoX's Avatar
Every engine and induction system is different as you already know... seriously just invest in a wideband so you don't have to worry.
Timing maps on the COBB stage 2 tune are fairly conservative IIRC, so just make sure the AFR's are OK. It would only take 1 dyno tuning session to confirm, so do that *shrugs*
Old Nov 29, 2009 | 12:05 AM
I don't know of any decent tuner in my area that can do this
Old Nov 29, 2009 | 04:47 PM
any Cobb guys out there that can give me an answer? Perhaps with the new ATR software will be easier to work with so I can do a little fine tuning myself?
Old Nov 29, 2009 | 06:15 PM
AWDTerror's Avatar
yes it would be fine. I ran the same, no issues, runs rich for me (10.9-11.0 AFRs) YMMV.
Old Nov 29, 2009 | 07:24 PM
ymmv?
Old Nov 30, 2009 | 08:25 AM
Golden's Avatar
your mileage may vary
Old Nov 30, 2009 | 12:59 PM
DRAG's Avatar
I ran this setup all last year with no issues, but I didn't run the revised map for the HKS filter. It was a little rich for me, so I just ran the standard Cobb Stage 2.
Old Nov 30, 2009 | 02:21 PM
lodifreefly's Avatar
I ran a similar setup (tested with both Cobb SFI and AEM intake using the proper maps for each) for a while and the only thing that I noticed with the Nisei UICP is that peak boost did increase about 1psi which took me from 26psi to 27psi spike at WOT. It only lasted a fraction of a second but it still made me nervous. Didn't have anything except the Cobb at that point for datalogging so I can't tell you much more than the impact it had on boost.
