Evo X unable to read or write using Ecuflash
Old Dec 27, 2009 | 03:31 PM
syncmotion's Avatar
Angry Evo X unable to read or write using Ecuflash
Today i copied JDM's Mivec map to replace ADM map and do a Reflash to my Evo x using tactrix open port 2, half way through it gave me an error and shut down the interface, and from then i could not read, write to the ecu. i have try method mention in openecu.org (remove pin 8 and put in to pin 12 on the obd port and do a recovery) this doesn't work after initiate the interface close and again i can not access to the ecu to load my original rom image.
Please help
