2008 EVOX MR, updated dealer flash, need help ASAP
Hi,
I've got a customers car strapped on the dyno right now. 2008, EVOX MR. He just had it in to the dealer to have an updated flash done for cold weather starting. EVOflash won't read the file.
Here is the file I pulled out and saved, not sure if this is going to help.
http://www.mediafire.com/?zztd2mimdze
Thanks for any help.
BTW, the car of course still runs, I just can't tune it like I had hoped.
ok its 52690022
put the attached file into your ecuflash...rommetadata\mitsubishi\evo directory
rename it to .xml (from .txt)
edit the xml should have inherrited 52690021
Thank you VERY much Tephra. I'm a little late getting back to this. I fixed the car so I could tune it and get him down the road by installing the 0019 ROM in it, worked out perfect.
My EVOX XML's have a lot of updating needed!
Thank you VERY much.
