Used AP question
Old Jun 12, 2010 | 12:50 AM
bojassem's Avatar
Question Used AP question
Allright, another newbie here
I'm about to buy a used AP. I have a X SST middle-east spec (which could be EDM as I've been told) with Cosworth Drop-in and yet to be installed CP-E catback. We use 95 and 97 RON fuel here in Qatar as the best option, 97 ROM is equal to 93 in the US if I'm not mistaken.
What's the appropriate OTS map for me? Should I do any tests first? Should I worry much? lol
Old Jun 12, 2010 | 03:41 AM
armysoldier1073's Avatar
Befor e i got my intake i had the K&N drop in and i used the 93 oct stock map. It worked great. You will be fine since your not changing the diameter of the intake tube and the MAF senso will not have to be adjusted. If you get a intake down the road, not all intakes are supported by the AP. You'll probably have to contact Cobb for which one to use if you go that route. Hope this helps.
