Cobb tune w test pipe?
Old Jul 20, 2010 | 03:26 PM
modthispny's Avatar
does cobb offer a map for just a test pipe? looked over there site and did not see anything.
really want to do a custom tune w test pipe, but after reading all these horror stories with dealers voiding warranties i want to go with a cobb AP since you can go back to stock without effecting the reflash counter.
Old Jul 20, 2010 | 06:16 PM
Golden's Avatar
You may just overboost with their Stage 2 maps. If you leave the boost pill in and use stage 2 you may be fine. If you over boost with that, try their LWG maps.
Old Jul 23, 2010 | 12:25 PM
Vivid Racing's Avatar
it doesnt look like they just offer a map for a test pipe but
"AccessTUNER Pro for the EVO X is available to the COBB Pro Tuner network. AccessTUNER Pro allows professional engine tuners to custom tune any combination of modifications to achieve their maximum power potential."
http://www.vividracing.com/catalog/c...i-p-58577.html
-anthony
Old Jul 23, 2010 | 12:54 PM
fostytou's Avatar
EvoM Community Team
Anyone's base flash should work fine if you just want a test pipe. That said, thats a horrible mod to be the only one to do to your car unless you are track only . Worst of the environmental impacts.
In any case, I'm not aware of the flash counter actually existing, I believe it is only a rumor still. The only thing I know if is the chain counter, and that has to be reset by a tech each flash... so AP would reset it just the same as ecuflash.
Old Jul 24, 2010 | 11:22 AM
curtisb's Avatar
nice
Old Jul 24, 2010 | 11:45 AM
SiliconTek's Avatar
I am running Cobb Stage 2 AMS 93 map and I was overboosting with my test pipe, especially at part throttle. We tweaked MIVEC a bit and scaled back WGDC and all is good now. Hitting ~25 PSI by 3500 and tapering to ~18 PSI at 7k.
Old Jul 24, 2010 | 12:04 PM
RedEvoxGSR's Avatar
i have jus a test pipe and was jus running stage 1 93
Old Jul 24, 2010 | 04:00 PM
SiliconTek's Avatar
You can go back to stock with Ecuflash also...
Old Jul 24, 2010 | 06:29 PM
ak47m203's Avatar
so means they did you a custom OTS?
Old Jul 24, 2010 | 08:04 PM
SiliconTek's Avatar
In the end HollywoodX and I did it. All they could recommend to me was to use a lower octane map, then when I hit boost max of 22, they said looks good to us, keep an eye on it. HollywoodX and I used a proven MIVEC map which totally eliminated the part throttle overboost, then we scaled peak boost back to the ~25psi range and then filled in the gaps and boom... Car pulls like a mother and there is no knock and max boost rests at about ~25.5 and AFR's sit nicely at mid 11's, boost is tapering to ~17-18psi.
Thanks HollywoodX! He did this **** for free, imagine if I had paid him $600...
Old Jul 24, 2010 | 09:45 PM
ak47m203's Avatar
Hollywood is the man.
Old Jul 25, 2010 | 11:12 AM
Golden's Avatar
Hollywood is a woman.
Old Jul 25, 2010 | 11:16 AM
SiliconTek's Avatar
With a manly voice to boot!
Old Jul 25, 2010 | 01:38 PM
ak47m203's Avatar
your making me confuse again...kidney is the lady right?
Old Jul 25, 2010 | 05:05 PM
SiliconTek's Avatar
I think he means HollywoodX used to be a woman, but now has an outie instead of an innie!
