error protected area (ecuflash)
Old Jul 28, 2010 | 05:14 PM
thekhmer's Avatar
im not sure what im doing wrong here but im trying to write a new rom onto the ecu and keep getting this error
[17:13:21.975] the image you are trying to flash contains changes to protected areas! exiting.
Old Jul 28, 2010 | 05:34 PM
tephra's Avatar
its because you arn't flashing a rom from the same series.
ie you might be trying to flash 53040010 over the top of 52680020
whats the current romid and the new romid?
Old Jul 28, 2010 | 06:51 PM
thekhmer's Avatar
im not even sure..the rom im trying to write is 52680018 and the one that i have (stock) is unknown says i have to make my own definitions or use the wizard im lost at that part
Old Jul 28, 2010 | 06:55 PM
tephra's Avatar
well you have a 2010 EvoX.
That will be 55570006 or 55580006 depending if its 5MT or SST.
Don't use 52680018
Old Jul 28, 2010 | 08:59 PM
Golden's Avatar
Looks like Colby's code just saved you from bricking your ECU.
mrmiller
Jul 27, 2016 07:34 AM
sleeper04
Jun 7, 2015 05:57 PM
prowakeskater
Apr 26, 2015 12:36 PM
fas-n-furyus
Jul 29, 2009 12:07 PM
GiGas
Jul 2, 2009 06:49 PM
