Suddenly lean throw me some ideas
Old Aug 8, 2010 | 10:25 AM
jpierson77's Avatar
As the title says I am suddenly very lean. Here's a little background; just installed new deats 1300, walboro 255 and a red. I was just starting to get things figured out ltfts within 3% I was pig rich at 10.5. Did a little maf scaling to try to make things a little better and suddenly I can't get the afr below 13. Swapped the fuel and high bram relay no change. Check the boost source to the fpr it was attached. Went back to my map that last ran rich it's lean now too. I'm gonna try cleaning my new inline fuel filter in case I got some junk in the fuel. Anyone have any other suggestions to look for?
Old Aug 8, 2010 | 12:08 PM
Gexxer's Avatar
the the FPR vacum hose nexct to the dipstick on the engine. there is a thread on here with pictures if you need it.
Old Aug 8, 2010 | 01:14 PM
jpierson77's Avatar
That was one of the first things I checked. It was attached I and throw a zip tie on it for good measure. I may pull the line and hook it to my brake bleeder to ensure there isn't a hole in it.
Old Aug 8, 2010 | 01:40 PM
ak47m203's Avatar
busted hfc if you have one or exhaust leak near the wideband sensor.
Old Aug 8, 2010 | 01:53 PM
Golden's Avatar
Put the MAF Scalings back and see what happens. If you are still lean, then there is a mechanical problem.
Old Aug 8, 2010 | 01:57 PM
jpierson77's Avatar
No cat but I'll check for exhuast leaks
Old Aug 8, 2010 | 01:59 PM
jpierson77's Avatar
Went back to the last map that ran good and was still lean so pretty sure your correct is a mechanical issue.
Old Aug 8, 2010 | 02:03 PM
ak47m203's Avatar
so check for exhaust leak, any code? im no expert but who knows.
Old Aug 8, 2010 | 05:23 PM
jpierson77's Avatar
Can't find any exhaust leaks. Tried altering the Naomi change. Leads me to believe it hast to be one of three things. Fuel pump, injectors or maf went bad. I can hear the pump when I turn the key to start and not press the clutch pedal and it sounds normal. Does anyone have or no of a way to test a maf?
Old Aug 8, 2010 | 09:30 PM
Golden's Avatar
You will throw codes if the MAF is bad.
Did you check the Vacuum hose that connects to the FPR under the valve cover cover?
Old Aug 8, 2010 | 10:53 PM
tephra's Avatar
what wideband?
Old Aug 9, 2010 | 07:16 AM
ak47m203's Avatar
check your wideband sensor, there is a vidz in aem site...
Old Aug 9, 2010 | 09:17 AM
jpierson77's Avatar
It's an aem, I'm leaning toward it being correct because the car will not run wot, it pops sputters knocks it's just awful up top. If it was pulling hard still but aem was reading lean I would consider the wideband being off.
I have no codes so maf must be functioning. That leaves fuel delivery I'm gonna fuel pressure Gauge and check for a possible air leak post maf pre turbo.
At least I thought I was having trouble with the injectors at closed loop. Begining to think whatever this is might be the culprit of that problem too. The car seems to struggle maintaing 14.7 it oscillates around a lot. What about the front o2 sensor going bad? If it's not reading correct this might be the cause of everything no?
Old Aug 9, 2010 | 09:19 AM
jpierson77's Avatar
There is only one vac line to the fpr correct? If so it's been zip tied and had no affect on the problem. I did clean my inline fuel filter it didnt have anything in it.
Old Aug 9, 2010 | 10:36 AM
charon2123's Avatar
Pull the injectors and make sure the o-rings are still good. Try a boost leak test to see if you are leaking air somewhere.
