Which map?
Old Aug 8, 2010 | 02:56 PM
glomb23's Avatar
Which map?
Probably an easy answer to this question, but I'm new to the accessport/tuning of the Evo. I'm currently running Perrin stage 2 93 octane map, but just ordered an aFe dry flow intake, and picked up a cobb turbo inlet. What map should I run with those additional things. I'm going to get Ivey Tuned on the 16th, but until then would like to install these parts and still run safely. Thanks for your help.
Old Aug 8, 2010 | 04:58 PM
Nauticabri's Avatar
They do not have an OTS map for your specific setup, you'd need a custom tune to be safe.
Old Aug 8, 2010 | 05:49 PM
glomb23's Avatar
So would you say to wait to put on the parts until I get to Ivey's shop? Would it be unwise to run the AEM Stage 2, AMS stage 2, or Injen stage 2 with the intake and turbo inlet? Any more input would be much appreciated. Thanks again.
Old Aug 8, 2010 | 06:28 PM
Nauticabri's Avatar
I definitely wouldnt run it hard if you do put the parts on b4 the custom tune. If you have the ability to Id say just hold off let them throw the parts on and do the tune all together to be safe.
Old Aug 8, 2010 | 07:03 PM
glomb23's Avatar
That's probably what I'll end up doing then. I just wasn't too sure. Thanks for the advice.
Old Aug 9, 2010 | 06:06 PM
glomb23's Avatar
would it be okay to just install the turbo inlet since I believe it does not effect AFR?
Old Aug 9, 2010 | 07:31 PM
Golden's Avatar
Yes.
Old Aug 9, 2010 | 11:28 PM
glomb23's Avatar
Originally Posted by Golden
Yes.
Thanks, much appreciated! I'll post some numbers after my Ivey Tune.
Old Aug 11, 2010 | 10:35 AM
glomb23's Avatar
Anyone else have further opinions?
